992 GT3 and GT2RS Forum 2019-Current
DIY Spark Plug Change
Old 09-25-2022 | 08:58 PM
GrantG's Avatar
GrantG
Default DIY Spark Plug Change
I just did my first spark plug change (1 year and almost 10k miles) and it's like the 991.2 DIY Spark Plug change, with the following changes:
1. New spark plugs are weird looking (the electrode that attaches to the coil is totally different - I thought I had snapped off the top when I saw the first one, but that's how they look now)
2. They are using a much improved connector to the coils (I hated the old connectors and the new ones are very intuitive and easy to use - just slide back a little yellow locking clip to remove and slide it back to lock). Press on the large black tab that the yellow tab locks to remove from coil.
3. There is no longer a sensor in the way of the left forward plug, as with the 991.2.
4. Plug torque is 23 Nm (fresh install or replacing used ones same torque now) and the screws that hold the coils down are 9.5 Nm.
5. The 8 black screws that hold on the 2 heat shields (one per bank) and the 6 silver coil screws are all T30.
6. There is some unusual yellow lube (1-2 mm thick application) that is used on the end of the boots for the coils (and some of this stays on the old plugs - you can reuse this at least once in my experience - rub this part of the old plug onto the boot ends). I'm sure you can buy some fresh stuff if you prefer, but make sure you get the right stuff from the dealer.
7. It's very helpful to have a variety of different length socket extensions (and some wobble ones too).
8. Same Hazet 4766-2 plug socket as 991.2, or equivalent
9. When removing coil screws, no need to screw them all the way out of the coil (helpful to have them attached) just out of the cylinder head.
Weird connector on top of new plugs:
Fancy Italian made Aluminum-Silicon-Magnesium alloy heads (and notice new coil connector with yellow locking tab - connector removed from coil and coil screws removed):
Original plugs with lube residue:
BTW, I don't think the change is required until 2 years. I was just being a little proactive (plugs looked good)
New plug and coil parts at Suncoast (I reused the coils - new style different from 991.2):
https://www.suncoastparts.com/produc...2gt3plugs.html
https://www.suncoastparts.com/produc...2gt3coils.html
The following 22 users liked this post by GrantG:
Chris C. (09-26-2022), Clay (08-22-2024), Diablo Dude (11-04-2022), Doublej (09-27-2022), EMdoc (05-20-2024), f1soul (11-24-2023), Gabriel@NutCracker (05-20-2024), GT3 Mike (08-20-2024), jayely1 (09-25-2022), Jbravo23 (09-25-2022), Mercuriell (09-26-2022), MovingChicane (06-25-2024), nerdtalker (09-25-2022), Peruna (08-12-2023), raymort (09-28-2022), RENNtorq (09-25-2022), Rxpert (08-14-2023), ShakeNBake (09-26-2022), smellycat (08-09-2023), subshooter (09-26-2022), wageslave (08-20-2024), WernerE (05-20-2024) and 17 others liked this post. (Show less...)
Old 09-25-2022 | 09:55 PM
Jbravo23's Avatar
Jbravo23
Most helpful guy on the renn. Appreciate you taking the time.
The following 7 users liked this post by Jbravo23:
Diablo Dude (08-08-2023), EMdoc (05-20-2024), Gabriel@NutCracker (05-20-2024), GrantG (09-25-2022), jayely1 (09-27-2022), raymort (09-28-2022), subshooter (09-26-2022) and 2 others liked this post. (Show less...)
Old 09-25-2022 | 11:10 PM
4carl's Avatar
4carl
GRANT, great post it’s good to have somebody on the form that’s not afraid to do their own maintenance.
I am a firm believer in doing all of your own maintenance..
Assuming you have the skills, experience and the tools
It’s not about the money it’s about taking the time to do it right..
Extremely helpful thanks! Carl
The following 6 users liked this post by 4carl:
cwbrown (08-09-2023), Diablo Dude (08-08-2023), GrantG (09-26-2022), old6string (10-08-2022), rodneyr (09-26-2022), subshooter (09-26-2022) and 1 others liked this post. (Show less...)
Old 09-26-2022 | 09:56 PM
rodneyr's Avatar
rodneyr
Good Information. However, I would think the change would have been around 30,000 miles? I never heard changing the plugs at 10K. Seems like solving a problem that does not exist. Maybe it is just me....
Anyways, helpful information!
pddickwin (08-21-2024)
Old 09-26-2022 | 10:12 PM
4carl's Avatar
4carl
i think factory says 2 years regardless of mileage.
GrantG (09-26-2022)
Old 09-26-2022 | 10:32 PM
GrantG's Avatar
GrantG
Yes, even if never driven. I think proposed theories include galvanic corrosion between steel plugs and alloy heads as well as the boots becoming welded to the plugs with heat over time (I guess this yellow lube is meant to help with that).
Old 09-26-2022 | 10:35 PM
GrantG's Avatar
GrantG
Was with a a 991 GT3 RS and 991.1 GT3, but a couple members had poor running due to worn plugs in a very short time (fewer than 10k) that was cured with new plugs.
I also have a feeling that frequent changes will keep the coils in good shape (I think worn plugs are bad for coils).
Just being a little overly cautious, I’m sure.
I’m sure 2 years is fine, but wouldn’t go indefinitely because someone has low miles.
Old 09-27-2022 | 01:24 PM
GrantG's Avatar
GrantG
I spoke to Suncoast yesterday and they added the lube that goes on the opening end of the ignition coil boots here:
Ignition Coil Grease : Suncoast Porsche Parts & Accessories (suncoastparts.com)
Airbag997 (03-13-2024)
Old 09-27-2022 | 01:32 PM
subshooter's Avatar
subshooter
Grant - How long did it take you? I'm sure you have done this a lot so you are probably more proficient than most.
Old 09-27-2022 | 01:42 PM
GrantG's Avatar
GrantG
It takes a couple hours if you're slow like me. Good idea to save this job for a time when you're removing the rear wheels anyway (gives much better access and no need to remove the undertray/diffuser).
And I think it's always recommended that you change plugs when the engine is cold (not just to protect your hands, but I think it makes for a better install and more accurate torque value).
subshooter (09-27-2022)
Old 09-27-2022 | 01:46 PM
4carl's Avatar
4carl
did you have to pull the fender liners?
Old 09-27-2022 | 01:57 PM
GrantG's Avatar
GrantG
No - everything is right there with the rear wheels removed.
Also, I don't think you're supposed to use anything on the spark plug threads - just dry...
Old 09-27-2022 | 02:35 PM
GrantG's Avatar
GrantG
Originally Posted by Reece Harvath
grant
the other replacement stuff at 12,000 miles/2 years is:
cabin filter
pre cabin filter
the engine air filters and the drive belt are 24,000 miles/4 years
Thank you, Reece! Nice that the engine filters and drive belt are longer intervals - No need to pull the rear bumper for a while.
Old 09-27-2022 | 09:36 PM
neanicu's Avatar
neanicu
You can always use dielectric grease made by Permatex and it only costs 9$. Porsche doesn't make that grease,nor do the other car manufacturers. I have personally seen a Ford original silicone branded by their in house parts supplier Motorcraft...and if you removed the Motorcraft sticker you would find a 3M product underneath. In this case,perhaps Porsche afforded completely rebranding the dielectric grease tube and not just slap a sticker on top to cover the original manufacturer...
Old 09-28-2022 | 01:45 AM
raymort's Avatar
raymort
@12k miles, is that so it’s not covered by the free 1st year maintenance cycle??
GT3Laguna (09-28-2022)
Quick Reply: DIY Spark Plug Change
