Hi! Can anyone post precise dimensions of a 992 GT3 trunk please? I need to buy a proper bag for an ED in August and don't want to mess with the rear seat space (getting LWBS).
In 2017 I tried my luggage on a 991.2 C2S at the dealer and was fitting fine, but then when I was in Germany to pick up my 991.2 GTS I realized it did not fit. So this time I prefer to have the actual dimension on the actual car.
Please if possible get the minimum dimensions within the trunk, since the bottom of the frunk tends to be smaller.
Really appreciate the help here! Thanks a lot!!!!
Stefano.
The trunk is narrowed in the front. You would be safe assuming 15.5" high, 15.5" deep, 27" wide as long as you account for the front corners by shaving a little off either the depth or the width.
Thanks a lot! This is super helpful.
Would you mind noting the height at the front and the one at the back? I guess 15.5 is the minimum at the front. How taller does it get at the back?
Looks like the trunk liner is the same for the 911 C2S as it is for the GT3 based on the Suncoast parts listing.
Given that, it should be about what @Dan Nagy measured it at here.
I saw that, but the width is quoted at 23 inches, which seemed way too narrow compared to what I had for my previous 991.2 GTS. The rest seems reasonable.
Bummer. Looks like the Away medium luggage (Exterior measurements 26" x 18.5" x 11") can't fit.
i think that might fit. 26.5” wide, 18.5” tall, 11” front to back gives you some room to move the luggage towards the back where the frunk is taller. I’ll measure in a little bit.
@touringGT3
That should fit, but it will be tight. This box is 18" tall x 25.5" wide x 5" deep. The back of the trunk angles backwards a couple of inches from the bottom to to the top, so I set the box up so that it was plumb to the bottom. Your bag is 0.5" taller and should clear the hood. Depth is fine. You have about 1" to spare on the width. My photos are not great, and my mock-up leaves a lot to be desired.
photo should say just under 27” or just over 26.5”
@touringGT3
Appreciate taking the time. This is great. Thank you! Yeah, I was worried about the 18" height not clearing the hood, but with the luggage placed in the rear then the front height might not be an issue. Thank you again.
Great pics and info! Thanks a lot! In the end I decided to go safe and get something smaller, not targeting the perfect fit. Well, I would trade reusing a pair of stinky socks any day to hear that NA orchestra. And if you drive it right, I think the passenger should worry more about Gs than smell!!!!
Yes, I know, it's disgusting
