CAN bus tap in location
I'll be hooking up my VBOX this week. I believe you can tap into the CAN bus via the pax fuse box area.
However, it should be available off of the ECU, which I understand is super easy to access under the rear carpet area. Can anyone confirm you can tap into it there? If so, do you know the wires? I have the non-intrusive tap, so I am not going to cut and splice.
I will be installing my roll cage soon and want to get all wiring done in advance.
Joe just installed his. Maybe he can share. I typically go for the driver fuse area - it's always worked for me in that location, not to mention easy access to switched power. Rear area would be more convenient however, especially if you do a rollbar mount for the HD2.
raymort (11-24-2021)
I guess an option would be to cut the cable in half and add a piece in between - but that is very undesirable.
VBOX CAN Bus
You can tap the can bus from either the left or right footwell fuse panels. Once you pull the bigger cover off they are pretty easy to identify. It's the brown and green twisted pair. I tapped on from the passenger side and put the box in the glove compartment. Ran all the wires up from underneath/behind the glove box with out taking anything apart. Nice clean install and easy access to the Vbox.
I double used double sided tape to glue a length of 1" square aluminum tubing to the bottom of the vbox, and velcro at the front of the box to secure the front of it to the inside of the glove box.
see the attached PDF for Vbox wiring. I don't know about going straight off the ECU.
Erf, yeah, you can't extend that method. We've had trouble with the inductance method before - but you should try it before you give up on it.
Glovebox install
Glove box install is sweet. So easy to access from the driver's seat. when I take the chip out for review, I leave the glovebox open, so that when I get ready to go out on track, it's obvious if I have forgotten to put the chip back on the box.
Just need to be sure it's not sliding around such that it can damage itself, cables, or surroundings. There is no accelerometer in it, it differentiates high res/high speed GPS position for acceleration.
If Joe got it to fit in glovebox, that's probably where I will put it. To secure a bit better I'm handy with a 3d printer.
raymort (11-26-2021)
Best (and coolest) solution is their rollcage mount and one rollcage camera mount for 2nd camera. Mounted high on cage with easy access to SD card. Run main Camera, Mic, and OLED over door under trim. Use 3M backed cable clips on window to run cables across top of the window, and go-pro wire camera ties to OLED, Camera tied to rearview mirror.
