992 GT3 Prototype - Secrets hidden in plain sight, or not.
#32
#33
The tape on top of the shifter has possibly something more to hide, unless it's what we have already been told by AP - a manual shifter being the same for PDK cars with label identifying the shifting pattern/method. Time will tell.
#34
Originally Posted by Drifting
I was thinking that Porsche wouldn’t make it easy to do a DIY Touring.
I’d love to have things both ways, but I’m sure someone at PAG wouldn’t allow it because it affects their profit.
#35
#36
I don’t know. But I think they learned their lesson and so won’t do that for the 992 GT3.
I hope I’m wrong. I would love it if 992 GT3 could be enjoyed both ways.
#38
I think Porsche "learned their lesson" by properly designing a feature for the 992 so you can remove the wing and make it look completely natural, properly finished AND be aero stable. The Duck Tail alone should still add sufficient stability for the 95% of the driving most will do. It will still look unique "GT3" as the Touring prototype photos look to use the standard 992S spoiler design.
It appears that those plastic panels below the rear window pop off to access a few bolts to remove the wing.
The 992 GT3 design nailed it!
#39
It would be pretty interesting! Good sleuthing. If you look closely, though there is your typical "PRND" stack on the gauge cluster of the "PDK" 992 GT3, whereas the truly manual 992 does not have that detail. The underpan strakes are a detail I had not noticed, and goes to show how Porsche are pulling out all the stops on this one... I'm sure there will be some other surprises as well.
#40
Originally Posted by CarManDSL
Any wing can be removed, just that the 991 GT3 would have required a complete engine lid replacement to look finished. Plus the remaining duck tail wouldn't have provided much down force. The GT3 RS was the easiest but didn't look finished. However, there are countless aftermarket engine lid options sans wing - some good, some ugly and probably not aero balanced.
#41
#42
I suggest what we are seeing with just the PRND is only part of the story. What about M± and the actual forward gear # selected?
We await the surprises!
#43
Carrara, if a Jekyll and Hyde tranny is fitted as I suggest is technically possible, then I would assume that the PRND on the display would change to reflect the current mode. The 991's display the PNRD but also the M± all the time and then indicates with a red dot the current setting. The 992 PDK simply displays only the current gear as in "P" and nothing else.
The following 2 users liked this post by Chris3963:
-eztrader- (01-03-2021),
Drifting (01-02-2021)
#44
#45
Originally Posted by Chris3963
You guys are all just throwing darts in the air. In fact, it the exact same gearbox as the 991.2 GT3 with a different design and covering over the PDK selector. That is all.
Now.. tell us about the movable underbody-aero solution which works in conjunction with the suspension to create the suction-effect we saw in the video.
