How to keep Bluetooth as selected source
I am not able to figure this out by reading the manual so maybe someone on here might know. Each time I get into the car the stereo reverts to FM radio, so each time I have to wait about 20 or so seconds for the bluetooth to connect from my phone then select it as the input and then I can play music from my phone. Is there a way to make it permanently so that you don't have to go and select Bluetooth every time? I have the Bose Stereo system.
I have the same complaint and to be honest this is not the main problem with the Bluetooth audio. In order to be able to stream audio through the Bluetooth, you must open the music app first on your phone, if not, the Bluetooth option may not even show up on your car.
With my iPhone 7 when I start the car it reverts to FM stereo then after about 10 seconds I can select Bluetooth Audio, then at that point it will pick up where I left off playing and start playing automatically. So if I'm using the TIDAL app for music it will automatically start playing the song I left off on once I select bluetooth. My main complaint is just having to switch back from FM stereo every time I start the car.
With Tidal I use a wired connection, I think bluetooth gives a quality loss.
But the same problem with wired. If the car is restarted after a few minutes, settings seem to be restored, but not overnight.
I would like to see PCM, AC/fan, and all button setting (Sport, PSM, etc) restored always. If PCM and/or fan was off, leave them off, if PCM dimmed, leave it dimmed, etc.
