Need a wheel guru's help pls ...
So how would the following be for fitment on a 13 C2S ?
Wheels:
Fronts: 20 X 9, ET 50
Rears: 20 X 11.5, ET 45
Tires:
Fronts: 225/30/20
Rears: 295/30/20
Wheels:
Tires:
Fronts: 225/30/20
Rears: 295/30/20
the fronts will be they will stick out 7 mm more than stock (like running a spacer)
the rears will stick out 25 mm out. thats 10 more than running 15 mm spacers...way too much.
you should be running 20x9 et 45 and 20x11 et 55 for a perfect fit with no spacers.
Agree with all of the above. BTW, it is almost certain that the wheels in your post are designed for a wide body.
I have that sizing/offset on my C4S's rears and they work fine there but would not work well on a narrow-body car just as ltdodge specifies.
