How much downforce does stock 991 spoiler produce?
Well aware my friend -- have driven on those roads myself Was just talking about the US. Where the tail actually is useful isn't on the Autobahn or in street driving, but in high-speed turns like a sweeper on the track. Even on the Autobahn, you're not turning at the limits of adhesion at 150MPH, where a couple hundred pounds on the rear wheels is going to make a difference.
I lived in Germany more than 35 years and have driven there most of my driving life. Had quite a few highspeed runs ...
When the tail lifts or you activate it there is extra air to the engine courtesy of the air dam (at least thats the case on the 991.2
On the new GT3 it's 155 kg, or 340 lbs, at top speed. Since aero forces vary with the square of speed, that means about 49 lbs at 74 mph.
Rocky Mountain High
Rocky Mountain High
I never understood the hatred towards those that leave the wing up like this. Yet people are okay with the duck tail, GT3 spoiler, and TT/TT-S backends. I think it makes the car appear a bit more aggressive (just like the higher end models). Instead of hating on or picking on others, let's just play well together and encourage and lift each other up. We are all part of a rare and exclusive club when considering the many in this world who can barely even afford necessities for basic life.
For example, there is a recent thread in the 997 forum that is now 4 pages long where people are arguing about whether the 991 is "bigger" than the 997, even though the numbers published by Porsche show that it is not. Even when faced with data and facts, people in these forums will argue.
Try not to take any of it personally!
From the 2012 991 press release:
The rear spoiler extends to different heights and at different angles depending upon vehicle speed. It also features a flow element on its leading edge. The element is controlled by a special pivoting kinetic mechanism to assure optimal airflow over the spoiler blade. As a result, downforce approaching 200 pounds can be applied to the rear of the vehicle at maximum speed when equipped with the optional 20 mm lower Sports Suspension.
Here is a link: http://google.com/patents/US20090286461 It's a bit of a hard read, but the most readable explanation of the flow element is found in the detailed explanation of the drawings section near the end of the document.
Rocky Mountain High
Link doesn't work for me.
