4S Tire Pressure Setting Question
Old Apr 23, 2017 | 01:15 PM
mrmojom3's Avatar
mrmojom3
Default 4S Tire Pressure Setting Question
I've been looking into my perceived rough ride. Well I came across a number of threads on the "comfort tire" settings. It appears my tire pressures may be waaay to high which is making the ride harsher.
I went into the menu option and confirmed the comfort setting is on for my 20" summer tires. I have a 14 C4S with SPASM.
Current readout in cold garage is
33 FL 35 FR 42 RL 42 RR
When I look as the fill into it shows
+3 FL
+4 FR
+9 RL
+9 RR
"Comfort partly load." - what does this mean exactly?
So dumb question - does the "+" mean the tire is over filled? So +3 means I can drop by 3 lbs of air? And I can drop the rears by 9 lbs of air?
Based on thread's Ive been reading, 42 in the rears seems really high.
I sure hope I need to drop pressure which will make my ride more compliant fingers crossed
Old Apr 23, 2017 | 01:29 PM
Larry Cable's Avatar
Larry Cable
Team Owner
+3 FL
+4 FR
+9 RL
+9 RR
if you check the owners manual, or on the drivers door jam, it lists the recommended cold tire pressures for the various loads, your rears are *way* high... but get a decent air pressure gauge to set the pressures...
Old Apr 23, 2017 | 01:38 PM
CSK 911 C4S's Avatar
CSK 911 C4S
Yes lower them by that number and you will be amazed at the difference.
I run comfort PSI settings +1 and PASM on NORMAL most of the time.
Old Apr 23, 2017 | 01:42 PM
mrmojom3's Avatar
mrmojom3
Doh! Thanks Larry. Should have taken the last step to check the manual.
Comfort is 30/33. Obviously I need to go let some air out. Should have checked that while at the dealer yesterday....
Old Apr 23, 2017 | 05:53 PM
Penn4S's Avatar
Penn4S
I have a 4S with MPSS 20". I run 31 fronts cold pressure and 34 rears cold pressure. Ride is great and grip fantastic.
Old Apr 23, 2017 | 06:21 PM
spiderv6's Avatar
spiderv6
The dealers often are clueless. I got a replacement rear fitted Friday on my C4S (damn nails!) and they gave it back to me with 45 in the rears and I forget in the front but waaaay too high.
First thing I did when I got it home was to clean the rim (seriously....can't these techs clean off the gunk as they go!) and fix the pressures.
Old Apr 23, 2017 | 08:22 PM
mrmojom3's Avatar
mrmojom3
Well, I did reduce air to align to the comfort settings. Car is definitely improved. So glad for this forum to help me out! I would have had no idea.
