Agate vs GB cleaning
Plan on trading my 2014 Agate cpo for new 2017 base Graphite tomorrow if all works out. For those who have had both colors is the GB as easy to keep clean as my Agate?
Really doesn't make a difference in the buying either way.
Received 5,413 Likes
Good looking car. That color appears to be a color to mask dirt better than the darker color of Agate.
If you want an easier way of keeping your car cleaner, longer, and a way to make the actual washing process also easier, look into a nono coating installed by a professional. I use OptiCoat Pro. There are several. Find a top notch detailer in your area, and use a product he recommends.
Get ready to clean seat belts with the seat belt cleaner you ordered. Popular seatbelt cleaners are available, like the Chemical Guys CWS20316, the Foam Cleaner XWEBFHU, the DP 310 Seat Belt Cleaner, and more.
Spray the seat belt cleaner liberally onto the belt. Seatbelt stains should be scrubbed with a soft-bristled brush for 10 seconds after applying the cleanser.
To prevent fraying and fabric damage, gently scrub the belt along the webbing with the cleaning brush. If the stain is still noticeable, spray more solution on it and brush it more frequently.
