Strange squeak
Old 04-28-2017, 02:37 PM
DY369
DY369's Avatar
Default Strange squeak
When I open my door first thing in the morning, right as I open the latch there is a squeak in the rear tire well area. I'm sure it's something charging up, fuel pump, etc.
It's just kind of annoying and I'd like to lube, fix, repair.
I've attached a video.
Anyone know the possible culprit? Might have to turn up the sound a bit.
Old 04-28-2017, 02:50 PM
LexVan
LexVan's Avatar
Received 5,388 Likes on 2,509 Posts
To me, it sounds like a faint "chirp" (only a single chirp, not the normal double) from locking the doors. Not sure what's going on there.
But, the good news is that you have very fresh tires from the 37th week of 2016!
Old 04-28-2017, 06:05 PM
DY369
DY369's Avatar
Yes tires seem great
I originally thought it was the exhaust valve opening up for start up, but there is so much going on back there who knows.
Interesting that whatever it is is timed to happen when the door latch opens.
Old 04-28-2017, 06:24 PM
LexVan
LexVan's Avatar
Do you have Enter & Drive? A lot of stuff starts to wake up once the cars knows it's going out to play.
Old 04-28-2017, 06:33 PM
CSK 911 C4S
CSK 911 C4S's Avatar
I went out to my car and didn't hear the same noise but during the same sequence like in your video my window lowers. Could it be a squeak from the window mechanism or a rubber to glass squeak?
Lower your window and do this again and see if it goes away.
Old 04-28-2017, 06:39 PM
DY369
DY369's Avatar
No, just the regular key.
It only happens one time and only after it's been sitting a while (like overnight). If I drive around and get in and out during the day it doesn't happen.
Old 04-30-2017, 12:03 AM
Daohaus
Daohaus's Avatar
def haven't experienced that one. I just get the passenger window prime itself by doing the micro adjustment and sometimes i see my wipers do the same thing
Quick Reply: Strange squeak
