Putting a IPD Plenum in a 991
Old Feb 18, 2017 | 09:32 AM
Dan991C4's Avatar
Dan991C4
Default Putting a IPD Plenum in a 991
Deleted
Old Feb 18, 2017 | 10:34 AM
STG's Avatar
STG
Great product, and nice you documented it.
As a more informative DIY, I'm sure many guys would like some helpful audio explanations as well.
This is no easy project on a 991, so nice job accomplishing it. Left mine to the dealer. Not as talented as you.
Very happy with the IPD. Did BMC air filters too.
Old Feb 18, 2017 | 10:53 AM
Dan991C4's Avatar
Dan991C4
Deleted
Old Feb 18, 2017 | 12:42 PM
R_Rated's Avatar
R_Rated
Can you comment on the difference in sound?
Old Feb 18, 2017 | 01:53 PM
Churchill's Avatar
Churchill
Has anyone done a before & after dyno on this item? Same car, same dyno.
Old Feb 18, 2017 | 05:05 PM
Pacific German's Avatar
Pacific German
Super easy install. Takes a couple hours.
Old Feb 18, 2017 | 05:30 PM
2001f4s's Avatar
2001f4s
Default Performance
Can you comment on the performance improvement based on the installation. I had one on my Cayman and it seemed to improve throttle response, but I didn't experience any noticeable performance gains. Thanks
Old Feb 18, 2017 | 06:03 PM
Dan991C4's Avatar
Dan991C4
Deleted
Old Feb 18, 2017 | 07:54 PM
Duke I's Avatar
Duke I
I don't believe it. Super easy = trading out the side markers. This cannot possibly fit the easy category. Just say'n.
Old Feb 18, 2017 | 08:07 PM
Churchill's Avatar
Churchill
Originally Posted by Dan991C4
Mainly this is a flow efficiency improvement on a part of the total air's flow path.
Unless you have empirical evidence (i.e. before and after dyno), this is pure speculation. More airflow from a single bolt-on part can mean less power just as often as it can mean more.
Old Feb 20, 2017 | 10:23 AM
Dan991C4's Avatar
Dan991C4
Deleted
Old Feb 20, 2017 | 10:34 AM
NVRANUF's Avatar
NVRANUF
My purchase decision was based on that I've done sub-sonic velocity air mass flow modeling and design for piping systems. The features of the IPD design will increase volumetric air flow efficency into the cylinders feed tubes. Plenum has less turbulence with the flow diverter and dimples reduce boundary friction which can be quantified by fluid mechanics analysis.
With the increase air mass, some car's may need the air/fuel ratio adjusted to see power gains by increasing the fuel level injected and spark timing changed. Modern ECUs with performance driven maps can automatically optimize the AFR and spark timing for the minor plenum change. The COBB tuner maps does include IPDs plenum in the allowed hardware changes.
Of course Porsche engineers would never have considered such things...
But P.T. Barnum certainly did...
Old Feb 20, 2017 | 10:41 AM
STG's Avatar
STG
They did consider it. They saved it for the GTS model. Aluminum X51 Plenum. Accounts for 50% of X51 Powerkit gains.
The plastic OEM Carrera S Plenum
Old Feb 20, 2017 | 10:55 AM
R_Rated's Avatar
R_Rated
Have a part number on the flanking pieces?
Old Feb 20, 2017 | 10:59 AM
STG's Avatar
STG
No. Would like to know.
Not sure if the bottoms would fit on a non X51 car though?? The X51 may have a different piece they connect to?? Not sure.
Maybe our resident expert the real "Plenum" can find out. He just bought a GTS.
