Fixing a flat tire
Fixing a flat tire
I discovered I had a flat tire on my 2015 GTS with almost 3K miles on it today and I wonder how to best fix it. I can use the manufacturer supplied tire sealant to provide a temporary solution so the car can be driven to a repair shop, but doesn't pumping that goo into the tire add weight and compromise the tire's performance down the line? I get it that this procedure is what Porsche recommends, but would I be better off getting a flat-bed tow?
What do you think?
What do you think?
Received 5,413 Likes
Plug and patch. Where is the leak? Hopefully not in an area like the shoulder. The challenge will be finding a shop that handle the center locks. Can you remove and hand carry?
That's why I bought a breaker bar combo so I could bring the wheel to any shop.
If you don't track the car and the leak is far enough from the shoulder, you can drive with a (properly) patched tire without a problem.
Received 2,279 Likes
I've had two flats on my 2014 Porsche 981 in 31k miles.
1. Screw in rear tire at 6k miles which was too close to the sidewall (slow leak so still driveable to a shop). I took it to three Indy's to get it plugged. The first two wouldn't do it because the screw was too close to the sidewall and they saw it was a Porsche. The last one plugged it but would only take cash so that the transaction wasn't traceable - he didn't want liability. Tire lasted just fine until replacement at 18,500 miles. I drive the car hard too.
2. Second one had another screw in a front tire at 20k miles. It was a bigger leaker so I couldn't drive it. I removed the wheel and took it to an Indy for a plug. Brought the wheel back and replaced it and then brought the car back to get it properly torqued to 118 ft lbs. (1 mile away) I don't have a torque wrench. The car is now at 31k miles with the original OEM tire with this plug and no issues.
I wouldn't put the goop in the tire if you can help it. If I did, I would replace it. Plugs are fine unless you are racing the car or tracking it. Most of us are not made out of money so we need to make these kind of choices. It works.
I'm still trying to figure out why the F$%@ there are so many loose screws on the road in Delaware! lol
Good advice. I opted for lug nuts so the CL is not an issue. Haven't found the leak yet but I will pull the tire tomorrow and look for it. It wouldn't take air. If I replace one tire, doesn't the other side need to be replaced as well? That would be a drag. The tire has less than 5K miles on it.
FYI. It's a bitch to break the torque on the wheel bolts. 118 ft.lbs. is a lot. Eat a big breakfast.
Tire Rack will shave a new tire for you, if necessary.
