PDCC reservoir replacement at 60K miles.
#46
In my case they had to replace a hard line that the tech damaged when removing the bottle ..... if you replace the bottle alone the bleeding process might not be needed.
#48
The drip is definitely red though, and the fluid that's being talked about is Pentosin, which is green. This 2012 991 Carrera S only has 23k miles on it, and I doubt
this fluid has been changed - could it have been filled with regular red ATF from the factory?
#49
Really appreciate your doing that, I've a leak that seems to be coming from that pump and I was having a hard time understanding where the heck it was located!
Does anyone know if the active engine mounts have red fluid?
#50
60k or 6 year service has a list of items which include PDCC reservoir replacement, drive belt, AWD controller oil (if you have AWD), brake flush and depending on where you are with plugs, oil change and air filters is a scary amount of $’s from the dealer.
When I moved my car to Florida last year I already had plugs, air and cabin filters and brake flush done in Pa. I went to the dealer in Naples to get an estimate for PDCC, AWD controller and drive belt. They came with a first estimate @ $3500. And this was with the rear bumper coming off already for the heat shield recall. After I told them they were insane the service manager called to lower the price to $2800.
I found a great Indy in Bonita Springs with a Porsche certified tech that did everything plus for $1400. I’ll do my own oil changes. The dealer will rape and pillage for this service.
Miatavi (08-31-2023)
#51
#52
Looking at the picture above that really looks like pink coolant.
Is the coolant bottle anywhere near or is the overflow tube close by?
#53
Thank you again for this input. I always thought that coolant was green, however, I did a quick search, and on another thread, “Coolant leak“ it totally shows my situation. Using a car cover, I actually hadn’t noticed anything on the ground till this incident, though periodically I had a white-ish residue on my back bumper that bedeviled me. Now I realize that when I covered the car after driving, the fluid was dripping into the car cover, so whenever I dragged it off the car, I was now rubbing it on the car. Mystery revealed! Thank goodness it didn't eat the paint! It totally evaporates, so it’s not “oil” per se. It might be an overflow tube, or a coolant tank or fitting leak, but at least now I know where to start. Thanks for pointing me toward the possible culprit here!
CSK 911 C4S (11-01-2020)
#54
Hope it's not off topic...
My PDCC reservoir is overdue for replacement. The car is meant to go into hibernation so I was going to DIY a few maintenance task. One thing led to another on my list: oil and filter, engine air filter, spark plugs, and then while I'm at it, the serpentine belt. Up to this, I have tools and comfortable to perform, however, I learned the belt will lead right to the PDCC reservoir. Is there a need to bleed, and without PIWIS, is this a DIY job?
#55
#56
And if I don’t need to see the car dance, is bleeding the system necessary for the replacement itself?
#57
You do not want air in a pressurized hydraulic system. Removing the reservoir requires removing the pump which will introduce air into the system as some fluid is lost in pump and lines. The fluid is corrosive too and needs to be cleaned up quickly. That whole area of the car is pretty tight too.
C4SJOHN (06-24-2023)
#58
#59
Thank you all!!
#60
For the 991.2 generation cars it's Porsche part 000 043 206 56 which translates to Pentosin 202. This is from the part fiche that Porsche calls V-Pages. You can use Pentosin 11s for a top off since it is mixable with 202. I have both since 202 is used in Audi dedicated power steering systems and 11s was used as a hydraulic fluid in the older Audi systems that ran both the brake boost and PS. When my car is up for this service I will use 202.
