GTS PSE burbling - all but disappeared
I was in an accident and post body shop repair, my PSE burble is much more subtle than it was prior. It went to a dealer for a software update in the repair process. I've heard that a software update can change the characteristics of the exhaust. If so, can it be reverted by the dealer?
maybe the valve is stuck in closed position?
See if you can trade cars with the guy on this forum that wanted to program out the burble sound.
Rear end accident??
Not sure of the cause but I would check the vacuum line that goes into the exhaust. Check to see if it's come loose. Should see a small hose in the middle of the exhaust about 12" in from the cars back edge. It can come off and effect the PSE. If it's loose you can DIY or bring it in for service.
Originally Posted by pfan
Does the PSE still work, but simply no burble/pops/crackles on deceleration? (If that's the case, I'd like to have the same malfunction)
Originally Posted by 911boy
Mine burbles more when sport is engaged
Plenty of pops w/PSE on in Sport or Sport Plus. Problem is, this creates too much drama when driving around town. Consequently, I'm forced to drive in Normal mode w/PSE, or Sport/Sport Plus without PSE. (And I detest Normal mode due to the idiotic and unsafe momentary throttle hold on deceleration).
