How to Change your Air Filter
Pain in the *** for just filters? YES!
DIY SKILL = 1 EASY, anyone can do it if you have <1.5 hours to burn
https://youtu.be/pWU7beZdWNY
What a nice gift for the day! I had learned the essence of this from some posts, but this helped fill in the blanks. Thank you!
Not to be a poor sport since I appreciate the time and effort you took to make and post the video, but I wouldn't call it a '1' on the complexity scale. Why don't we call it a '2', especially given the fact that at 5:32 of your video I can clearly hear in the audio where you snapped off/damaged the connector that holds the wiring harness for the license plate light/reverse sensor (on cars fitted with them) to the inside of the rear bumper.
For info, the rear wiring harness connector plug is also a PIA to disconnect btw which is what I chose to do instead of just letting the bumper hang down with the harness connected like you did. I would love to see a close up video on how to properly remove that connector. I mangled the crap outta mine before it separated.
I did not break anything other than one of those caps that covers the taillight screws. Super fragile, but easy fix. The noise you heard was the bumper coming off, and part of it was stuck. OK fine 2, if dealer charges an hour labor to do it, not a big deal, but it's fun doing it yourself... Not like a brake pad job which might be a real pain.
Just for those folks who remove their rear bumpers, the tail light/reverse sensor wiring harness attaches to the inside of the rear bumper, is fragile, and if you attempt to pull the bumper clear of the car after only removing the screws and tail lights, the harness holder will break. Not the end of the world, but a note of caution as you DIY the rear of your 911.
PS - 911 brake jobs are super easy. A bit dirty, and almost impossible to salvage the brake wear sensors (one each per wheel!), but as always, with proper tools and safety precautions, a very manageable DIY job.
I should have chosen my words more appropriately. Not for me to say whether you did or did not break anything. Sorry.
TIA
This material is VERY brittle and will most likely fracture when you attempt to remove the sensor from the brake pad even when not worn out. I tend to damage half the four sensors when I do Porsche brake jobs. Porsche service techs don't even bother attempting to salvage the wear sensors when they perform brake jobs. They are automatically replaced regardless so they simply yank them out.
My advice is to buy all four and reuse those you salvage as you discover your own technique to remove them without damage. A pair of needle nose pliers and pulling the sensor straight up gives pretty good results. GL.
