Hi everyone. I have had my Awe Switchpath Exhaust installed on my 991.1 Carrera S for a couple of months and have really been enjoying it. Fantastic sounding system.
I had PSE before so have the full functionality of being able to turn it from "normal" to "loud" with the press of the Exhaust button on the centre console.
A few days ago I noticed that the exhaust button wasn't opening or closing the valves as it normally does. The sound doesn't change at all anymore and is stuck in the "valves open" mode I believe. I checked when I was in the garage with the car on and windows open - when I press the Exhaust button to "on" I can hear a slight clicking sound where the Exhaust is but the sound doesn't change. No clicking sound when I turn the button off.
I had this installed at the tuning department of the dealership I bought my car and they are 45 minutes away. However, I've been servicing my car at a dealership 8 minutes away and I have an appointment for winter tire swap over and oil change tomorrow. Is this an easy fix that I can ask this dealership to remedy while it is in service tomorrow. Is it likely something came loose? Has anyone had this experience with their Switchpath Exhaust?
the vac lines can easily come loose if not installed properly because the clearances especially on the drivers side valve are super tight. the ones shipped from AWE were a joke, and more like light surgical tubing prior to them (purportedly) switching to lines more like OEM.
I'll ask the dealership to diagnose tonlook at it tomorrow.
Are the lines or switchover valves considered part of the Exhaust itself or the PSE wiring ?
I'm wondering since the AWE Exhaust is aftermarket installed at another dealer (but the PSE button and wiring is from dealership) whether this would be considered a warranty item or if they will tell me it's aftermarket and won't cover it. Does anyone have any ideas ?
The valves are part of the AWE exhaust and would not be a factory warranty item. The PSE button and wiring would be covered. I'm pretty sure it's just a loose vac line. Grab a flashlight and slide under your car, you should be able to see the vac lines and if they are connected proper. It possibly could have come loose at the T connector as well. (see black tubing in pic)
Thanks! I'll ask at the dealership anyway tomorrow for them to have a quick look since it's going in.
had the same thing happen last month. Even though it was an AWE, the dealer didn't charge me anything reconnected the hose lines and said PSE was covered under warranty hehe.
Update: Just got the car back from the dealership. Apparently the vacuum lines were melted on the exhaust !!! They must have come loose and came into contact with the exhaust. This was repaired and the vacuum lines were secured (hopefully) properly.
Fortunately the dealership didn't charge me for this and put it under warranty although the service advisor did say they technically should have charged me as it was due to an installation of an aftermarket exhaust elsewhere.
That's the only thing that bugged me about AWE exhaust install. It didn't feel like an improvement removing the OEM steel braided vacuum lines and replacing them with chintz rubber tubing.
