Black Car "Swirls" and Paint Correction-Ceramic Coating
#47
Received 5,410 Likes
#48
Talk about prep, my truck sits outside so I used it on it. About killed me getting it all off. But a year later, nothing's sticking to it and it still beads up.
#49
Ceramic coating won't prevent swirls. I had 4 coats of ceramic coating put on one of my cars, and a year later I still had accumulated a few marks here and there (despite very careful car washing).
It does reduce the tendency to swirl but it doesn't eliminate it.
That's why it's better to get a new ceramic coating each year and get a reasonably priced one ($300-500) versus spending a lot ($1500+) and doing it only once. I speak from experience.
These coatings last a long time, and they will bead water for years. However they will still swirl at some level that is visible in one year.
#50
My experience - drying worse than washing for swirls
I use a waffle microfiber towel to dry my cars. You lay the towel over the area and pat it (no rubbing required) and it absorbs the water. Works quite well.
I got mine online at Esoteric Fine Auto Finishing
Gyeon Q2M Waffle Dryer Microfiber Towel. 24 x 32
$16.95
FWIW, I did paint correction, clay bar and alcohol cleaning then applied 22ple quartz finish. Done 2 years ago and still repels water and resists dirt.
Al
$16.95
Al
