Stuff that's weird about the 991.1
#76
The service person said the tech and Shop foreman agreed the gear selection is not supposed to show until the car is moving in that gear, he said that is how this "chassis" is supposed to work and there was some technical explanation that I couldn't understand. I again told him people from the Rennlist board in 991.1's said they don't have that issue so why would I. He said he was going to investigate it further and call me back. He suggested I ask if any one knows of a bulletin code or something that he could reference to show it may not be working the way it should. I know its a long shot but if any one has any ideas on how I can get this resolved I would appreciate it. My car is still at the Dealer so they can fix it while its there.
Thanks in advance!
#78
I'm having a hard time understanding -- is this supposed to be an actual problem? When you're in a gear, the dash says you're in that gear, but you want the dash to say you're in a gear 1/10th of a second sooner, like when you're shifting into that gear?
#79
But to answer your question with an example, wouldn't it be ideal to know if you were in Reverse gear before you started rolling backwards after having let off the clutch? Imagine shifting in to 1st accidentally thinking you were in Reverse and the car moves forward in to something or someone by mistake when you thought you were in R. This isn't a big issue but if the car can indicate what position the shifter is in before you are off the clutch that would be ideal.
We have had multiple people mention their cars work the way mine does as well as other who say they can see gear selection before releasing the clutch. If its a simple fix (Firmware) then my preference is that I get it updated as needed.
#80
I know it is not the model being discussed in this thread, but our Boxster-S (6 Speed MT) does not show the selected gear until the Clutch is fully let out. I agree I would like it to show what gear has been selected before you start moving. Particularly, as noted above, in First and Reverse.
#81
I've seen a number of people say this. What's the reasoning?
Even with the top down, there's still a need for good air circulation, especially in traffic. It could be argued that it shouldn't come on by default, but it's not as if the default level of airflow is obnoxiously strong.
#83
Ok guys I just got back from the dealership asking them to update the Firmware if need be since the Gear Selection in my Manual 2012.5 C2S does not show anything until I am completely off the clutch and gear engaged including in Reverse gear. I told them I knew people from the board who said their vehicle didn't exhibit this characteristic and I would like it fixed if possible.
Thanks in advance!
Thanks in advance!
I have experimented and can confirm that mid 4th to 3rd is a lite blip whereas mid 4th to 2nd is a pretty big blip - so it knows where it's going (this would not be a hard algorithm to program). So far the consensus is showing that those with autoblip (Sports Chrono in Sports+ mode) see the gear indicator prior to gear engagement or clutch release.
No idea if this is a simple software change.
#84
Rocky Mountain High
One thing that I've never understood is why you have to hold the button to put the cabriolet top up or down, as opposed to one touch operation like the windows. It's especially annoying when putting the top down, because the windows go up as soon as the top is open, so you then have to put the windows down again. My 997 was the same way. I know there are aftermarket solutions to address this, but it shouldn't be necessary.
#85
#86
#87
Rocky Mountain High
Yeah, the mods4cars SmartTOP is a must.... same for the Targa. I'm sure its a litigious USA issue surrounding a safety concern about fingers, arms, etc. (think backseat kids) getting caught in the mechanism without an quick/easy way to stop its function. I have heard its a single button flick in some other areas of the world. Same reason we get ugly warning stickers on our sun visors where they don't appear on cars elsewhere.
#88
#89
Just drive the car like you would if it did not have a gear indicator. Older manual cars did not have gear indicators, and people drove them just fine. I don't look at the gear indicator, I just drive the car and keep my eyes on the road. It's actually more fun this way and you feel more connected to the car.
#90
In my manual driving days, it was possible to feel the increase in pressure required to push the car into the new gear on the rare downshift into a potential money shift. I knew not to complete the push into the gear, or if I had I knew not to release the clutch before rechecking the shift. But that would occur maybe 1% of the time at most. The extra pressure in this case is due to the synchronizers requiring too much time and effort to sync up the big difference in rotational speed of the gears. I can't say that this exists in today's 911s as I don't have a manual one anymore, but I do know for sure that when I was driving aggressively enough to need to do this right I certainly didn't have time to be taking my eyes off the road to find a number on the dash to tell me what gear I was in.
