Installing lighted door sills
Old 08-12-2016, 01:51 PM
tampaukfan
tampaukfan's Avatar
Default Installing lighted door sills
I bought the factory carbon lighted door sills and cant find a DIY guide, can some post a link if there is one or tell me where to wire them into?
Old 08-13-2016, 01:09 AM
Homeles
Homeles's Avatar
Took all of 3 seconds. Google is your friend. Don't be afraid.
Illuminated Door Sills Installed! - Rennlist Discussion Forums
rennlist.com › ... › Water Cooled Technical Discussion Areas › 997 Forum
Jun 30, 2010 - After finding a "how-to" on removing the door panels, I decided to take on this task this early evening. After struggling to get the door panel off, ...
Installing lighted door sills 12 Aug 2016
Help - Illuminated Door Sills / Footwell lights out? 7 Nov 2014
Illuminated door-sill guards 16 Oct 2014
Instructions to install illuminated door sills 11 Nov 2009
More results from rennlist.com
Illuminated Door Sills 981/991 Retrofit Instructions - DIY ...
www.renntech.org › ... › DIY Articles - Boxster/Cayman (981/C) - Mods
Jan 16, 2013 - Ordered from Suncoast parts in the US as they where cheaper than the UK dealers, price was 599.95USD, the factory installed price in the US ...
Illuminated door sills ?? - Planet-9
www.planet-9.com › ... › 987 Cayman and Boxster Chat
ANybody know how to install it ?? Where i can get it, and how much would dealer charge to install as opposed to myself??
Porsche 911, 997 & 987 Boxster Cayman Inside Door Sills Installation ...
Video for install illuminated door sills 991▶ 2:39
Jul 30, 2010 - Uploaded by MAcarbon
do you have a video of how to install illuminated door sills? not the inside. ... Sorry, we don't have instructions ...
Anybody know how to retrofit the illuminated door sills ...
http://www.6speedonline.com/.../2975...ated-door-sill...
Jan 15, 2013 - I want to pick up some illuminated door sills. ... in labor to do it so I just installed the CF sills and didn't do the wiring. .... New 991 GTS, Alcantara seats, or leather with cooling, stratocaster69, 991, 20, 09-19-2015 09:57 AM.
Lighted Door Sills Installation Instructions - 6SpeedOnline ... 14 Dec 2012
Illuminated Door Sills Installed! - 6SpeedOnline - Porsche Forum ... 30 Jun 2010
Illuminated Door Sills - 6SpeedOnline - Porsche Forum and Luxury ... 16 Jan 2010
Illuminated Door Sills Installation - 6SpeedOnline - Porsche Forum ... 29 Dec 2005
More results from www.6speedonline.com
Old 08-13-2016, 01:23 AM
tampaukfan
tampaukfan's Avatar
Yes I am well aware of what Google is.. and I found all those links before I posted a question, none of which relate to a 991 illuminated door sill install.
Installing the sills is easy, wiring them up is my main concern.
Porsche 911, 997 & 987 Boxster Cayman Inside Door Sills Installation by MAcarbon - YouTube
Old 08-13-2016, 09:26 AM
LexVan
LexVan's Avatar
Received 5,413 Likes on 2,516 Posts
Tampaukfan, does this help?:
https://rennlist.com/forums/991/8850...n-991-c4s.html
Contact the Rennlister (Bigkraig) via PM, and see if he can tell you more. GL.
Old 08-13-2016, 05:36 PM
tampaukfan
tampaukfan's Avatar
Thanks Lex!
Old 10-28-2017, 09:02 AM
See U n RearView
See U n RearView's Avatar
Soon the 2015 GTS, Carmine carbon fiber interior GTS will be here...
I'd like to do lighted Door sills. Which finish do you think would go well in there...?
And I wonder if thers a way to change color of light...?
Old 10-28-2017, 11:48 AM
okbarnett
okbarnett's Avatar
you would have to buy different color leds and substitute them if you can
Old 02-12-2019, 03:11 AM
NCheok
NCheok's Avatar
Sorry to revive this thread, did you manage to get the installation instructions for your 991?
Old 06-04-2019, 04:13 AM
Crazy Eddie
Crazy Eddie's Avatar
Sorry to bring up an old thread
Before I call the dealer, I was wondering if anyone has the DIY instructions for putting these CF illuminated door sills in a 991 /981 GT car ?
Thanks in advance
Ed
looping (04-14-2022)
Old 06-04-2019, 08:31 AM
ryoryo
ryoryo's Avatar
Here you go
File Type: pdf
Old 06-04-2019, 08:10 PM
Crazy Eddie
Originally Posted by ryoryo
Here you go
Thanks very much
You are the man
Best regards
Ed
Old 02-16-2020, 03:56 AM
Paliknight
Paliknight's Avatar
I dont mean to revive an old thread, but I’m hoping someone can help out.
So i removed the old sills on my 991.2 TTS and installed the new ones, but am having difficulty wiring the harness. The harness is routed near the fuse box of the front driver’s seat, but I don’t know how to remove the front seat and plug it in. When i tried to splice it into the door light fuse, the sills dont turn off when the door closes.
Ive tried making a thread on here and looking at older installs, but none address my specific issue.
Old 02-16-2020, 05:05 AM
Crazy Eddie
didn’t this list help you ?
post #10
https://rennlist.com/forums/991/9487...l#post15885338
regards
Ed
Old 02-16-2020, 07:04 AM
Paliknight
Paliknight's Avatar
post #10
regards
Ed
I went over that, but since I’m a rookie at this stuff, I didn’t know how to remove the front seat. That requires another manual I couldn’t find
Old 02-16-2020, 10:49 AM
tgavem
tgavem's Avatar
Remove seats are easy.
Tilt seat forward, slide seat all the way forward. Remove plastic cover on rails.
use a E-12 torx (find on amazon) remove bolt from both rails.
slide seat far rear, remove plastic cover and front two bolts.
disconnect battery, let sit fro 5 minutes. While you wait. Rock seat and cover rail ends with cloth.
get a buddy to help remove seat, heavy and wire harness needs to be disconnected. Harness plug, pull on tab and then slides apart.
to reinstall, after front bolts are in, then connect battery. This way you should have no airbag issue.
Paliknight (02-16-2020)
Quick Reply: Installing lighted door sills
