Passenger side window control
On the driver's side if you push the windows down/up it controls the window with one button press. On my passenger's side you have to hold the button down. I tried playing with the controls there looked in the manual, but don't see any settings.
The passenger door was just repaired, so is it a problem with the repair or a simple setting?
You have to relearn the memory settings.
Turn key to ACC position.
Hold button down until window rolls all the way down, release.
Hold button down again for 3 seconds, release.
Hold button up until window rolls all the way up again, release.
Hold button up for 3 seconds, release.
Turn car off.
Should be fixed!
Turn car off.
Should be fixed!
