Ebrake gremlin. Has anyone seen this?
Sorry if you guys are getting sick of hearing about my car, but I had to start this thread to get some eyeballs after my 5 page thread below 'my troublefree streak is over'. After the dealership replaced my bearing and wheel subharness, now I seem to be having a minor ebrake issue. When the brake engages or disengages there is a 'stutter' in the middle of the normally smooth cycling and sort of a 'ratcheting' sound in the left rear where they were working. The dash indicator and ebrake button light flash for about 5 sec before going off. Usually they are on solid when the brake is on and off when it is off. Service manager looked at it with me before I left but did not have an answer except to comment that maybe the car is getting 'confused'. The brake seems to hold on a hill though not sure if I trust it. Any ideas? I just got my canned email from the dealership making sure I had a great experience and to be sure and fill out the survey from Porsche.
Jim
Jim
clearly - its not fixed
curious, how does it behave when you use the auto-off feature, you know, put it in gear, put your seatbelt on and drive off ... does it disengage normally.
I'm a bit confused and surprised that the dealership let you drive the car away with it exhibiting this
behavior which is clearly not 'normal' in an area where they were working ...
Jim
Post what they've done to the car. There are several members on the GT4 forum that have had problems with the Ebrake. It works just fine,but the light will stay on at times. I'm with Larry,it's probably software related. Just drive the heck out of the car and don't worry. Take it back to them at your convenience,they should be able to fix it while you wait.
The technician is saying that he was getting a speed sensor error on the PIWIS from the rear driver side. Then he goes on saying he swapped sensors and bearing from side to side to see if the error moves. This part I doubt...that's not an easy undertaking and it's something a DIY-er might do,not an experienced technician using the latest scan tool. Of course he ended up measuring resistance(which he should've done from the beginning) and it was low on the affected side. He then replaced the harness.
If he indeed ended up taking all that stuff apart,then he most likely had to play with the parking brake,which might be the reason it is not working properly...
There should be another page. It seems that the technician's description stopped abruptly because of lack of room on the page.
What you can read into it is, "Hmmph. This gadget isn't telling me exactly what's wrong, therefore I'm going to try random stuff until either the car starts working or 5:00 rolls around."
I had my wheel hubs replaced too, a couple of months ago also.
And I got also sorts of alarms about my e brake.
The long and the short of it was that my E brake pad gap need to be recalibrated 😳
Jim
Jim
Actually, there's not a lot you can read into the difference between 4.5 and 5.5 "mohms", regardless of whether the tech meant "megaohms" (M) or "milliohms" (m). Tiny differences in contact resistance could easily account for the latter (except that even a few inches of wire would have more resistance than that), while meaningless differences in semiconductor junction leakage or bias characteristics would account for the former.
Jim
I lost count of tires and brake pads!
Also knock tire off rear wheel figure I should just do all of them,
