Rear Wing Spring Failure
My 2014 Carrera S had been making weird knocking sounds the past few weeks.
It sounded like someone was throwing rocks at the rear side of my car.
Turned out to be the little spring that helps the rear wing go up and down.
It got knocked out of its position and when the rear wing would go up and down, it would make it click into the body panel. Having it replaced by the dealer.
Just FYI, if you hear this sound, check your rear wing movement to replicate it.
You might have the same issue.
