Small windshield chip - fix or ignore?
Old May 25, 2016 | 05:23 PM
...Max...'s Avatar
...Max...
Default Small windshield chip - fix or ignore?
That didn't take long
Too much construction going on in the area... just ate something that clearly disagreed with the windshield. It is real small -- I'd guess about 1.5mm -- but not far from the line of sight. I don't think I'll be particularly bothered by it when driving, but is it worth fixing ASAP so it doesn't get worse? Safelite?
On my earlier cars I'd probably ignore it, but thought I'd ask everyone's opinion to be on the safe side.
Old May 25, 2016 | 05:26 PM
LexVan's Avatar
LexVan
I can't see it. Get it repaired. Not replaced. About $75-50. Your insurance will probably pay 100%. If your wife asks, make sure you tell her that's at least 3mm.
Old May 25, 2016 | 05:51 PM
tomc_mets's Avatar
tomc_mets
Sir Thomas Lord of All Mets Fans
Is it in your field of view while driving? If not, and it doesn't bug you, I'd wait. If there's a lotta construction were you live, might as well wait until you get a real crack.
T
Old May 25, 2016 | 06:54 PM
Jnosol's Avatar
Jnosol
Call your insurance company. Chips are fixed at no charged as long as you have full coverage.
Old May 25, 2016 | 08:13 PM
Bigalfromfl's Avatar
Bigalfromfl
Hahahaha!
budrichard's Avatar
budrichard
FIX!
A chip or more correctly crack is a stress intensifier and can progress with less than the normal stress for cracking.
In some cases the effect can be spectacular but not with safety glass.
A polymer that sets up is injected under pressure into the crack.
Picked one up in my Boxster last summer.
Came to the house, fixed, no problems. $80. I don't even report these small things.
--Richard
Old May 26, 2016 | 06:40 AM
Karl911's Avatar
Karl911
Get the chip fixed ASAP, otherwise it will turn into a crack soon.
I have replaced my windshield 2 times already!
Old May 26, 2016 | 01:44 PM
Still restless's Avatar
Still restless
Yes. Fix ASAP. As others have said, most insurance policies cover 100% of repair cost (deductible is waived). Most repair providers can come to you for the repair. You can search for the providers online.
I just went through a windshield replacement on my S4 that started out as a small chip. The chip became a 12" crack when the car went over a dip and rebound section of the road while going around a downhill bend somewhat aggressively.
Old May 26, 2016 | 01:46 PM
...Max...'s Avatar
...Max...
I think the majority has convinced me -- will drive down to Safelite shop and see if they can fix this little pit. Thanks everyone for chiming in!
Old May 26, 2016 | 02:35 PM
...Max...'s Avatar
...Max...
Nada They can't do anything - plastic fill won't adhere since there's no crack to penetrate. And it turned out I have two more of these, just out of L.O.S. My luck, again.
Old May 26, 2016 | 02:52 PM
jimbo1111's Avatar
jimbo1111
Got one with only 300 miles on the clock. Fortunately it split a couple of days later and the insurance picked up the replacement. Used the best guy around and the installation was flawless. I don't recommend repairs. Always visible if in your sight. Will get on your nerves forever and cause you to hate the car.
Old May 26, 2016 | 04:56 PM
Gofishracing's Avatar
Gofishracing
Safelite for repair only- my feeling- not for windshield replacement on Porsche.
Old May 26, 2016 | 08:59 PM
Karl911's Avatar
Karl911
insurance will not pay for a chipped new windshield replacement, must be cracked.
Old May 26, 2016 | 10:02 PM
Jnosol's Avatar
Jnosol
That is correct, they will pay to fix any chips or cracks that's less than a quarter size. No deductible and your rate will not go up.
Old May 26, 2016 | 10:07 PM
jimbo1111's Avatar
jimbo1111
I have a glass insurance rider policy with no deductible.
