How important is a torque wrench for oil change?
I can't find one around here and my first change is coming up. I have watched a lot of good mechanics do a lot of oil changes over the years and I don't think I have ever seen one pull out a torque wrench. It got me wondering how important is this for the filter housing and drain plug?
Jim
Jim
J
Did he use a brand new crush washer? If not, the chance of the drain bolt backing out and leak increases.
A torque wrench is no longer needed on the 991.2's. Plastic sump with a plastic twist and seal plug. (The whole plug gets replaced at each oil change.) Super simple...and a little scary. Progress marches on.
When I did a mid-service oil change for track day, I used a torque wrench and it was totally necessary for me. I would have put the filter on too tight and the drain plug too loose without it.
For someone who has a feel for it, I'm sure it's completely unnecessary.
be sure to use a dedicated low , narrow range tq wrench, not one of those 20-250 ft lb ones used to torque down wheel nuts....which are basically useless and far, far off in terms of accuracy/ calibration below 50-60 ft lbs ...or you will be sorry , and better off doing it by " feel " like I have from 40 yrs of DIY oil changes and what seems like 40 cars !
btw , ALWAYS dial the setting back to ZERO after using a tq wrench and NEVER use it to break tq on anything ...use a breaker bar for wheels and reg wrench on drain plugs, etc
J
Here's an idea. Buy Once Cry Once!
Typically you will find that the lower ranges are in a 3/8" drive torque wrench. There are many good brands and you don't have to spend a lot on one.
An example:
http://www.craftsman.com/craftsman-m...p-00931424000P
EDIT: I didn't see post above. It does highlight, however, the range of tools available.
An example:
