Battery Charger/Emergency Bonnet Opener
Hey guys,
I was reading the active thread on the Porsche Battery Charger and the problems with the cigarette lighter location shutting down. I have always use the Battery Tender charger so I tackled the job today. It came out great.
The Battery Tender plug is accessible with the hood closed. No problems doing so.
When attaching the plug to the battery, as mention in another thread, the battery cable nuts will not come off so I used a spade connector and went to the not threaded (head end) of the bolt.
I have one of those emergency battery jumper things (have not had to use it yet) and theoretically it should give power the battery and open the hood then use it to start the car. I hope I never need to use it.
I guess my reasoning for this would be if a person had a dead battery while not at home. Most likely won't happen, but.............
Pictures now.
Pictures now.
I'm the thread starter on the other thread you mentioned. So you were able to loosen the battery terminal nut so you can slip the connector on the other end but you can't take the nut completely off?
You could put in behind the nut. I have before, but they deform.
I recently ordered one of these. It looks like I'm going to have to cut them since the nut won't come off
Amazon.com: CTEK (56-260) Comfort Connect 1/4" Eyelet for M6 Smaller Batteries: Automotive
