PSE Parts
Old 06-10-2016 | 06:09 PM
RobC4sX51's Avatar
RobC4sX51
Originally Posted by bittrl1000
That doesn't make sense to me, as the standard exhaust has two valves just like the PSE does, and the vacuum lines are effectively the same.
PSE allows you to "control" the valves in the center muffler via the control switch (electrically) at ANY rpm whereas non PSE S cars' cm valves are vacuum operated around 3500 rpm so so, with no direct control. The X51 Kit can be had & installed w/o PSE with no detriment to the performance but as you said, GTS cars come with the added bonus of PSE. PSE cars also have nicer polished tips! Hope this helps.
Quick Reply: PSE Parts
