Do you think my rotors are cooked?
I'd replace them or have a set of spares on hand. Go with slotted.
My car has 11k miles on it at this is the fourth set of rotors. That's what track days will do to you.
Received 5,402 Likes
Brad, when I do Tech Inspection for PCA events (DE and Club Racing) we inspect the rotors and pads, and a bunch of other stuff. On rotors, we are looking for these check/crack marks at the outer most edge. That would be bad. Yours look pretty normal with a tracked car. You do not have any cracks at the outer edges. I like Spyerx's answer, have a set of spares ready to swap out in the paddock.
I have another set of OEM standing by, but was hoping to get another track event with these. That said, I'm asking because I'm not sure if these are completely toasted or OK for another run. I honestly don't know how far they can go.
Any suggestions on a brand of slotted that isn't super expensive?
LexVan had the more complete answer.
Drilled rotors are toast when the cracks reach and edge (you need to look front and rear) or the crack touch hole to hole. Or they reach thickness limit. Porsche spec is less, like 5mm long cracks or something.
You'd probably be wise to invest in slotted rotors. They last a lot longer for track use.
Does cryogenic rotor treatment help extend lifespan?
Cryo? Who knows maybe.
Former Vendor
- The discs themselves look pretty worn (5-6 mm of radial crack from the drill holes according to Brembo Racing and also a visually noticeable lip on the discs).
- If you have a 991"S" model, Brembo upgraded discs (350 x 34 - Front, 350 x 28 - Rear Type 3) and RT RE10 endurance pads. Nothing available for non-S models from Brembo (the only brand we choose to sell). PM us for more details or RL pricing.
- Cryo must not help, Brembo or AP (the two leading brake suppliers) don't really offer / do that for their racing discs.
my .02 Drilled rotors on track will not last any where near slotted rotors....
