Window stops Unlearned Solution?
Old Feb 20, 2016 | 11:18 AM
woodranch's Avatar
woodranch
Default Window stops Unlearned Solution?
I believe my passenger window stop has become unlearned. In other words, it is not sitting flush against the molding and sticks out a little. The driver's side is 100 perfectly flushed. Is there a simple fix or best to take it to the dealer for some more difficult fix? Thanks in advance for advice!
Old Feb 20, 2016 | 11:22 AM
Porsche_nuts's Avatar
Porsche_nuts
Try this and let us know if it works.
To reset (car must be on):
1) lower the window all the way down and release the switch
2) push the switch down, hold it there for 3 seconds, and then release
3) raise the window all the way and release the switch
4) pull the switch up, hold it for 3 seconds, and then release
5) turn car off and then back on
Old Feb 20, 2016 | 11:43 AM
woodranch's Avatar
woodranch
Ho Porsche_nuts but that did not work.
Old Feb 20, 2016 | 02:28 PM
Porsche_nuts
Try this -- let us know if this works
Close window completely once by pulling the rocker switch
If window is completely closed, briefly pull the rocker switch again 3 times
Open window completely once by pressing rocker switch
Old Feb 20, 2016 | 02:44 PM
woodranch's Avatar
woodranch
Nope that did not work either, Thanks for trying.
Old Feb 20, 2016 | 04:22 PM
woodranch's Avatar
woodranch
Probably did not explain myself real well. There is not a probblem with the window going up or down. The problem is when the window is completely up and the car is locked, the passenger window is not flush with the molding at the top ,where is meets the small rear window. The drivers side window sits completely flush. Thanks again....
Old Feb 20, 2016 | 06:16 PM
Porsche_nuts
Sorry it did not work out. Guess a trip to the dealer then.
Old Feb 21, 2016 | 01:03 AM
Dewinator's Avatar
Dewinator
Did you try, when you turn the car on, pausing at "on" before you turn the ignition to "start"?
Old Feb 21, 2016 | 01:20 AM
beaverlake's Avatar
beaverlake
I think I get it - sounds like an alignment issue. A dealer can adjust the angle that the window follows as it closes. From what you wrote it seems like an adjustment is the answer.
Old Feb 21, 2016 | 07:56 PM
woodranch's Avatar
woodranch
Thanks, I think it is an alignment issue too. Will take it to the dealer.
