Another set of P-Zeros down.
At 16,759 miles on this set of P-Zero's they are dead and this weird pattern developed on one of my rear tires. Has anyone seen this before?
I probably drove on these a few more miles than I should have and they let me know it.
I'm thinking these are "WTF are you doing" indicators since the driving experience went down hill quick the last hundred miles.
Car is C4S w/SPASM and PDCC.
At 16,759 miles on this set of P-Zero's they are dead and this weird pattern developed on one of my rear tires. Has anyone seen this before? I probably drove on these a few more miles than I should have and they let me know it. I'm thinking these are "WTF are you doing" indicators since the driving experience went down hill quick the last hundred miles.
Wow, I thought comfort was more like 40 rear, but I have mine at comfort/ "full load" to help protect my wheels on our crappy potholed roads. 34 sounds more like a track pressure to me. I guess I'll have to do some research and make sure I'm not over inflated! In your most recent pic the wear looks a little more even.
17,000 miles on a set of 911 rear tires is great. I'm happy with anything over 12,000. I needed new rear tires last summer at 16,000. Some here are getting 20,000.
Take an exacto knife, and cut into those blisters. What do you see? Probably almost corded, is my WAG.
Did you happen to notice if that was comfort normal load or comfort full load? I think there is a 6 or 8lb difference depending on the computer tmps setting you use. I'll look later when I'm in the car.
For the C/CS the Full Load/Comfort is F31/R40
1st P-Zero - 9,314 (bad alignment from factory/cupped/noisy/frustrating)
2nd MPSS - 18,086 - even wear/quiet right up to the end
3rd P-Zero - 16,759 - even wear/not as quiet as the MPSS at the end
4th P-Zero - I could not wait for MPSS got a good deal from Tire Rack
It looks like the area of the tire that is abnormal could have been caused by small contact patch from excessive tire pressure. This could impair heat dissipation under hard use. The OP has now posted that he was drifting and if tire pressures were high, the contact patch (limited by high pressure) could have melted down. I have melted P-Zero's at the track using pressures that should not have resulted in the melting.
