View Poll Results : What is your default multi-function display screen?
Multi-Function Display Poll
02-09-2016 | 01:33 AM
Quote:
Originally Posted by
2001f4s
Water, Oil Temperature, and Oil Pressure view is my go to
Plus voltage. Upper line is driving range, lower is time/temp. I removed a number of display options from the rotation to make scrolling quicker.
02-09-2016 | 08:00 AM
2001f4s
Same here, with the addition of the compass on the 4th line.
02-09-2016 | 10:16 AM
2001f4s
Mine too..
02-09-2016 | 10:27 AM
Miles to empty, Water and Oil Temperature, Oil Pressure, Voltage.
02-09-2016 | 10:28 AM
2001f4s
+1
02-09-2016 | 10:32 AM
CSK 911 C4S
That's what I have as well
02-09-2016 | 01:13 PM
2001f4s
+1
02-09-2016 | 01:52 PM
Vehicle info, with Voltage. Speed limit at the top.
02-09-2016 | 01:54 PM
I had two flats back to back within the first 5 weeks of ownership. Since then I keep my eyes glued on TPMS at all times.
02-09-2016 | 01:57 PM
DerekS
TPMS should throw a warning when you have a flat ... or even just low pressure
02-09-2016 | 02:07 PM
Leader
Oil Temp
Water Temp
Distance to empty
Altimeter
This.
02-09-2016 | 02:34 PM
Larry Cable
It absolutely does. I'm just paranoid about it now.
02-09-2016 | 03:44 PM
Dude174
speed limit
water temp
oil temp
oil pressure
remaining miles until empty
+1
02-09-2016 | 03:54 PM
water temp
oil temp
oil pressure
voltage
02-09-2016 | 06:44 PM
Top to bottom:
Speed Limit
Oil Temp
Water Temp
Oil Pressure
Miles to empty
