Home air pump?
#31
Interdynamics Truck Air. 275 PSI. Cost about $50 IIRC. Portable. It's worked great for over a decade of heavy use. Loud though.
#32
I use the Kobalt. It's reasonably priced and works very well. You can set the desired PSI and the unit is fairly accurate and is generally well matched with the onboard TPMS readings.
