DIY Oil Change Question
#31
It is this Durametric Kit?
$287
Choose this option if you have a Porsche 911 (1996+ 993, 996, 997, 991), Boxster, Cayenne, Cayman, and/or Panamera.
http://www.durametric.com/buyus.aspx
$287
#32
Received 5,413 Likes
$287
$287
#34
Seems this is more $$ efficient if it works, I have yet to try it.
How to reset oil service light Porsche 911 Carrera 2014 - now - YouTube
#36
#37
A long time ago, I took someone's advice and bought 2"x8" (or 10s?) at Home Depot and cut them into, I don't remember, maybe 2', 4' and 6' sections. Then nailed them together with the back ends flush. It makes for very solid ramps and is perfect for accessing the drain plug on a 991. The only slight negative is that they are a little heavy and cumbersome to move around. You can feel each new level as you back up onto them, so you know when you are at the third (top level). Extremely easy to use, cheap and available everywhere.
