991 radio problem on startup
Old Jan 7, 2016 | 08:32 PM
rodjac's Avatar
rodjac
Default 991 radio problem on startup
Wonder if anyone else has this problem. About once a week when I start the car the radio sounds like five stations playing at the same time or maybe an old record played at high speed. If I shut off the car and start again the problem goes away. If I just shut off the radio and then turn it back on again the problem persists.
Old Jan 7, 2016 | 08:37 PM
Jabs1542's Avatar
Jabs1542
If it's still under warrantee you should take it in. If not, it may be one of those little features you get over. Seriously though, a PCM reset (if that's possible) may be in order.
Old Jan 7, 2016 | 08:44 PM
rodjac's Avatar
rodjac
Thanks jabs1542. A 2014 still under warranty. It was a feature I was getting over because rest of car is so great but will mention it at next service.
