Front wheels jump
A good point people have made is that Google works well at pulling up Rennlist hits. Larry had a good trick too about adding something to the end of your key work to pull up more Rennlist hits on searches. Larry???
Yes, the RL search function bites! I agree. As do many features on the mobile apps.
The OP did try, so no big deal.
Hi all!
Has anyone felt a pulsating or jumping of the front wheels when turning sharp (almost to stop) when going very slow. Like backing out of parking place. Seems more pronounced when cold. Almost feels like tires are trying to grip. My 997 did this but was a 4S and since the front tires had drive, it was normal. Did a search but didn't come up with anything. TIA as always.
https://rennlist.com/forums/991/8949...om-lexvan.html
Great article in the latest Panarama magazine about this. Describes why it happens and for good reason! As said above, the wider front tires are the big issue. I have 19" winters w 235s up front and it is almost non existant now for winter.
type in the google search bar
site:rennlist.com + what you are searching for
No, these are the current-generation MPSSes, which didn't have Porsche's stamp of approval. I'm not sure you can buy the N-spec MPSSes at retail yet, or if there's any difference.
My front tires are smaller than most people here will be running (235/40ZR19), but I still experienced a lot of 'acorn' bumping with the original Pirellis at temperatures in the < 50F range. It's definitely less pronounced now -- in fact, I haven't noticed it at all.
The Pirellis were a bit livelier in the steering department than the Michelins, subjectively speaking, but in all other respects the latter appear to be better. I haven't had a chance to try them in heavy rain yet but I don't expect any surprises vis-a-vis the Pirellis.
