Detailersdomain Black Friday's Discounts!
To get your car truly clean, you have to really dry it. If you're not into keeping it that clean then it's not worth the coin. But comparing the masterblaster to some rags is just night and day.
And if you want to save energy probably choose not to own a Porsche?
looking at this unit as well. Do you have any issues with shooting dust and debris out while using as a blower after using it as a vacuum? If not, it doesn't look like there is any downside to this unit over the master blaster and you get a vacuum.
When using as a blower, you switch the hose to the opposite side which then sucks in air.
Just tried it out. When using as a blower, there is a whistling sound on the intake side. Sounds like restricted air trying to be sucked it. Still blows a good amount of air.
Overall, even at 50% on the Master Blaster, it seems like more air output than Vac N Blo. The Master Blaster also has a thicker hose. Having both blowers on for 8HP is insane. Ear piercing when the air hits lug bolts, trim pieces, etc.
Tough call! Since I have both units, obviously I just use the Van N Blo exclusively as a vacuum and the Master Blaster as a blower. Perfect combo. If you have a vacuum already, I'd go with the Master Blaster.
The Master Blaster will blow ALL water off your car. Especially if it has a coating or wax. Seriously, you'll only need one microfiber to go over it with a quick detailer for small water beads. That's it. No dozen towels, etc. The only microfibers you'll use is cleaning door jambs, under hood, etc.
I have the master blaster as well. It's fantastic at getting water off the car, wheels, etc. I have had a few issues with mine. Sometimes the hose pops off, not a huge deal but kind of annoying. I also had the ground portion of the plug break off. I still need to contact them about that one. Even using this I sometimes still get some water coming out of the rear lights when i drive it for the first time after washing.
If you got up all the known water holding spots, you barely see any water come out. One secret area is the rear badge and front crest. Tons of water under those.
Tail lights, head lights, door handles, window trim, mirrors, and rear deck are a few others. Like mentioned, the water just flys off all panels too reducing drying with towels.
When using it as a vacuum it blows air out the opposite side.
Just what I needed to hear. Went with the master blaster and some polishes Thanks for taking the time to write and posting the pictures.
A great blower though. I don't see how some guys use leaf blowers?? Air isn't even focused and you're blowing up everything around your car too. Keep us posted on what you think later.
My pleasure. You'll be very happy. The Master Blaster (funny name huh), has two switches. 4HP each. One is heated air. Can use one at a time or both at the same time. I find myself using just one as the air power is insane. Usually the non heated one. That one tends to dry the water and leave dry spots. Great for blowing out wheels as well. I'm telling you, you'll barely need any micro fibers. A great blower though. I don't see how some guys use leaf blowers?? Air isn't even focused and you're blowing up everything around your car too. Keep us posted on what you think later.
In the warm months when all my washes are done outside, I prefer to stick to my Echo gas blower for getting water out of the wheel area, jambs, headlights and taillight bezels. Works like a champ.
However in the winter for the inside the garage washes, nothing like heated air from the master blaster. Great product.
Quality towels. A good quick detailer, good leather protectant, a gallon of 303, Ragg Topp if you have a cabriolet, a syringe of Optimum Gloss for your wheels and a high quality sealant for the paint. Good micro fiber wash mitts. A quality wheel brush. Foam cannon.
https://www.detailersdomain.com/coll...ressure-washer
This is a great opportunity to invest in the best pressure washer in the market.
Do you think that K2017T is better than the K1122TST? They both have the same "cleaning power" factor of ~2800, but the K1122TST looks like it has a nice auto on/off feature, while the K2017T is always on. The K1122TST is also on sale for about $270 cheaper on their site.
