Why does Porsche use P Zeros?
Okay so if you decide to go with non N-Spec Michelin Super Sports from Tire Rack, which ones should you get? There are a whole bunch on there. BMW spec. Mercedes spec. No spec.
Me, I prefer to stick with the Porsche recommend, but I do miss the Michelins that came on my Cayman and Boxster. There's something missing with the P-Zeros. Can't quite put my finger on it, but they don't have the same 'feel' the Michelins did. I'm actually enjoying my 20" Michelin Alpine snow tires more right now on dry pavement.
Okay so if you decide to go with non N-Spec Michelin Super Sports from Tire Rack, which ones should you get? There are a whole bunch on there. BMW spec. Mercedes spec. No spec. Me, I prefer to stick with the Porsche recommend, but I do miss the Michelins that came on my Cayman and Boxster. There's something missing with the P-Zeros. Can't quite put my finger on it, but they don't have the same 'feel' the Michelins did. I'm actually enjoying my 20" Michelin Alpine snow tires more right now on dry pavement.
If you want more feel, add 2-4 more PSI. I really think these PZeros have been great tires. I can't out drive them. Then again, I don't track or autoX or drive in rain. I plan to try the MPSS in mid summer 2016. I also expect them to be excellent, but I'd be surprised if they are better than the Pirellis. We'll see.
You want no spec.
If you can wait it might be worth holding off until the N-spec MPSS appears?
we should ping damon@tirerack to see if he has an eta on those.
You want no spec.
I track the pzero. They are better than they have been in older generations. They are not as good as pss. And they definitely aren't as good as mpsc2.
If mpsc2 is a 10 for aggressive driving/de. Then pss is an 8.5 and pzero a 8.
Hope this helps.
You want no spec.
if you look at the side profile of the 991.1's OEM PZero N0 , they were purposely made more square-shouldered by Porsche's request in order to get better tire wear and maximize the advantages offered by the then new 991.1 model's redesigned rear suspension which featured much improved camber and toe control vs the 997 and before . This was relayed directly to a buddy of mine with direct line to Porsche chassis engineers in Germany.
Notice the generic MPSS that many 991.1 owners have bought so far has a comparatively more " rounded " shoulder side profile . I suspect the coming 991.2 oem MPSS NO wil be more " square shouldered " than off the shelf versions .
Waiting for N-spec MPSS to come out of back order is really getting old.
At this time we have no ETA on when/if there will be an N-Spec SS in the 911's future. The only N rated SS we presently show is 255/40 20 and 295/35 20. If Michelin plans to produce in 991 sizing soon, we would probably know sometime hopefully in the spring.
Turns out the N1 Pirelli's are now available.
If you look at the side profile of the 991.1's PZero they were purposely made more square-shouldered by Porsche's request in order to get better tire wear and maximize the advantages offered by the new 991.1's redesigned rear suspension, which featured much improved camber and toe control.
