What is the correct Blendmount model for the 991 GTS?
Thanks.
https://store.blendmount.com/blendmo...ies-p1784.aspx
1) Does having active LED headlights (and the camera behind the mirror) make a difference in the part number for the GTS?
2) What is the part number for the invisible cord?
3) Is there a power take-off near the mirror for the invisible cord to plug into? I've seen the posts about grabbing power from the fuse area but I'm hoping to find something closer to where the V1 is mounted.
2) Don't think there is a part number, just get an inviscord
3) Yes, but it does require you take apart the mirror housing, diy instructions are here:
https://rennlist.com/forums/991/8047...re-of-dog.html
not the easiest to do because it is to tight, but it has been done.
