How much the 40000 miles service will cost?
7th Gear
Hi there,
My Porsche is a 2012 911s (991 model). It's approaching 40000 miles. The P dealer ask for $2200 plus tax for the 40000 miles maintenance. I also called a body shop and they said they could do the same job under $1000. What should I do? Anybody know what's important to change at 40000 miles?
Didn't the dealer give you a breakdown of what's covered? Ask them. They'll provide it. I would assume that service is listed somewhere online. Doesn't seem far fetched for the price/mileage.
Body shop?? Are they quoting service or a front end repaint for rock chips??
Maintenance Checklist – 911 Carrera/S/4/4S (991) (2012-on)
Required Maintenance and Lubrication Service
* Oil Change Every 10,000 miles or 1 year.
See Below Check Box.
❏ Maintenance After 40,000, 80,000, 120,000, 160,000 miles etc.
Note: If the mileage for scheduled maintenance is not reached, maintenance must be performed no later than after
4, 8, 12..... years.
The terms ‘check’ and ‘inspection’ include all necessary subsequent work such as adjusting, readjusting, correcting and topping off, but do not include repairing, replacing and reconditioning parts or assemblies.
Electrics
❏ Diagnosis system: Read out fault memory; reset maintenance interval
❏ Windshield wiper/washer system, headlight washer: Check function and nozzle adjustment
❏ Horn: Check operation
❏ Tires: Check tire pressure (TPM)
❏ Batteries and ventilation hoses: Check condition
❏ Electrical equipment as well as indicator and warning lights: Check operation
Inside of Vehicle
❏ Pollen filter: Replace filter element
❏ Seat belts: check function and condition
❏ Door locks: check function
Front Luggage Compartment
❏ Pollen filter: Replace pre-filter element
❏ Check front lid lock and safety hook of the front lid for secure seating and function properly
❏ Windshield wiper/washer system, headlight washer: Check fluid level and antifreeze protection level
❏ Check firewall body drains for debris
Outside of Vehicle
❏ Check wiper blades
❏ Vehicle lighting: Check operation
❏ All headlights: Check adjustment
❏ Radiators and air intakes: Visual inspection for exterior debris and blockage
Under the Vehicle
❏ Drain engine oil
❏ Vehicle underside and engine compartment: Visual inspection for leaks (oils and fluids) and abrasion (lines and hoses); Underbody panels: visual inspection for completeness, secure installation and damage
❏ Tires: Check condition
❏ Brake system: Visual inspection of the brake pads and brake discs for signs of wear (without removing wheels)
❏ Brake hoses and lines: Visual inspection for damage, correct routing and corrosion Check brake fluid level
❏ Steering gear: Visual inspection of the dust boots for damage
Tie rod ends: Check play and dust boots
❏ Axle shafts/Drive shafts: Visual inspection of the dust boots for leaks & signs of damage/wear
❏ Exhaust system: Visual inspection for leaks and damage; check mounting and heat shields
Engine Compartment
❏ Air filter: Replace filter elements
❏ Change oil filter and fill engine oil (Every 10,000 miles/15,000 km, see separate Oil Change Sheet, PNA 000 162 LC)
❏ Fuel lines and connections: Visual inspection for damage and leaks
❏ Visual inspection for leaks (oils and fluids)
❏ Coolant: Check level and antifreeze protection level
❏ PDCC: Check fluid level
Additional Maintenance – Replace Spark Plugs
❏ Replace spark plugs: every 40,000 miles / 60,000 km or 4 years
Additional Maintenance - Drive Belt
❏ Check drive belt at 40,000 miles (60,000 km) or every 4 years
❏ Check drive belt at 100,000 miles (150,000 km) or every 10 years
❏ Check drive belt at 160,000 miles (240,000 km) or every 16 years
Electrics
Inside of Vehicle
Outside of Vehicle
Under the Vehicle
❏ Drain engine oil
Engine Compartment
Martin S. (08-20-2021)
Service prices vary significantly from State to State, but they can also vary significantly within a State. I live in MD and there are three dealers within an hour of where I live. Two year maintenance prices for these three dealers for the two year service went from a low of $640 to a high of $930, and this was for precisely the same set of services recommended by Porsche at the two year interval.
Never schedule a service without asking for the price of that service. I've found that service prices are negotiable just like the asking price of a car.
Main things done at 40K are spark plugs, air filters, cabin filters, and oil change. The rear bumper needs to be removed to access the engine air filters. My local dealer wanted $1400 for this.
I did it myself with the help of a mechanic friend for about $325 in parts and a couple hours of our time. Removing the bumper looks onerous but is quite easy. A dozen or so Torx fasteners hold it and the taillights on, there are online pictorials and videos showing the procedure. The clip itself is light and easy for two people or even one to remove.
I'd really suggest trying it yourself, $2200 is a total ripoff.
MTSCOTT is right, the main things are plugs and airfilter. While $2200 is high, that sounds about right for a P dealer in CT.
Call an indy, its about 3hrs of work.
I think you could replace the plugs just by removing the wheels although the bumper off gives you a little more elbow room. I also wouldn't assume the CPO dealer changed the air filters early.
Bluegrass (09-22-2021)
can you replace the sparkplugs without removing the bumper? reason why I ask is im am coming to 40K miles, my car was a cpo with 26K miles. i am sure they changed the filters. not sure if they did sparkplugs. i was thinking of just changing the oil and sparkplugs because all the other inspections were done 10 months ago.
Porsche is like many manufacturers using time or mileage as a basis for service. The question I have is if you have 20K miles at 4 years do you really need to do the 40K service? Do you really need plugs at 20K?
