Problem with my key 911S
So here is my question. I have a 2014 911S. I moved my car this morning with my spare key which is not set. I then got back in the car an hour later with the key that I programmed originally but now the comfort access is not working and my mirrors are not folding when I locked the door. Is there a quick fix for this?
It may be that you have auto memory set in MFD. If so, whenever you lock your doors it memorized the last setting in your car. Thus, when you used the spare key that was not programmed and locked the door with it, the car memorized the "non programmed" settings for that key. I think the only way to fix is reprogram the car and memorize it to both keys then take auto memory off. If you like to keep auto memory on, save your settings to #1 and/or #2 also in the door memory so that if you take your car for service and they memorize a different setting, you can press #1 or #2, then re-memorize your key. Hope this helps and sorry you have to redo your settings (unless you already saved it to #1 or #2).
I have that happen once in a while when I use my spare key.
I believe it usually correct's itself if you lock then unlock the car with the key you always use.
It actually did correct it self the first time. The other day it did it again and nothing. I went into settings and the comfort mode and retracting mirrors were deactivated. Weird. But I turned them back on. All good now.
