Going to try and change out my Disk and Pads
A few years too late but in any case the video below goes over the basics:
<iframe width="560" height="315" src="https://www.youtube.com/embed/hhvZZAZHJEw" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
https://www.partsgeek.com/rqwdyft-po...oaAo51EALw_wcB
this is pretty much the best you will find. ($140 for each front rotor, rears are usually much cheaper, even though they are the same exact size). All the companies know that your fronts wear much faster so they triple the price of the fronts and change them ever so slightly so you can't interchange them with the rears.
Brembo front and rear spec sheets both 28mm thickness:
https://www.bremboparts.com/america/...isc/09-D935-11
https://www.bremboparts.com/america/...isc/09-D930-11
Sebro front and rear specs both 28mm thickness:
https://www.fcpeuro.com/products/por...er-99735140101
https://www.fcpeuro.com/products/por...ro-99135240100
