14 991 S- memory
I was curious on how to reassign the key in the memory for the seats mirrors and all the presets from the previous owner to me. I read the instruction manual and it is way too confusing. Any help would be appreciated.
The way I do it. With the key you want to set in car and car running.
1. Set all your settings: climate, seat position, mirrors etc.
2. on drivers door, press left button (set), then the position number you want, ie #1
3. on drivers door, press left button (set), then far right button with the key symbol, you will hear a tone
4. turn off car, get out, lock door with key fob, do not use button on door handle to lock car
5. should be set next time you get in.
I do this all the time as I am constantly changing the heat/air setting and seat position and want it for next time.
