Turbo Brakes on 991 S ?
Would the S be the same as a 4S? Assume so?
http://www.6speedonline.com/forums/9...ml#post4222856
I'm curious - are you looking to upgrade the brakes for styling reasons or do you find yourself running out of brakes on track events, etc? If the latter, there are less costly ways to improve your braking performance.
Track events. Original rotors have only 1-2 more events in them. Not running out of brakes. I use Pagid yellows and SRF fluid. Works very well, but if I am going to change rotors I would like improvement if possible. Have checked out Girodisc and Brembo rotors but they are pricey. 38mm turbo OEM Porsche rotors are about 400 less than girodisc.
I've got about 70 track days on my 991c4s. Originally, I ran stock rotors and pads.
My first upgrade was to move from stock pads to Pagid R29s. The Pagids made a huge difference as my stock pads literally would melt during heavy track work. I really like the modulation and stopping ability of these pads particularly in light of the great longevity I've experienced.
After moving to Pagids, I found I would crack through the stock rotors after 5 to 6 track days. After looking around, I decided to replace the stock rotors with GiroDiscs. Like you I was initially dismayed by the price, but my local shop was able to put together a good deal for me. After going through two sets of rings(no need to replace the hats), I can say without a doubt it was the right decision. Much better wear and significantly improved breaking. The Giros were able to handle heat much better than stock cross drilled. In the end, the cost of Giros were cheaper particularly if you are planning on doing a large number of tracks days.
I'm going to assume that you're not planning on swapping out the calipers - which I've found to be fantastic (no break pad taper etc.). As a side note: you might want to keep an eye on the brake pad springs. I had to replace both the right and left rear springs which somehow got "twisted".
fester (01-03-2020)
Yes, pads and rotors are def wear items, the price we pay to play on the track. Are you still running street tires or have you moved to R-Compounds? You won't believe how fast the car can stop on a set of warmed-up R-Compounds if you are still running streets....Sounds like you have the pads and fluid up to speed ....
