Aluminum Pedals
As anyone installed these? http://www.suncoastparts.com/product...91S_InteriorSU
I know there was a thread awhile back but most of the discussion was around SPR and other manufacturer which required you to drill holes in the pedal. I'm not sure if this configuration would really help with heal-toeing? Thanks!
Can anyone help with the instruction please? I'm looking for instruction on how to install it too...
There was instruction with photos somewhere, but somehow I couldn't locate it now...
If I recalled what the instruction said correctly, everything but the gas pedal is a direct replacement (snap & go I suppose). The gas pedal requires replacement of the entire unit...which means using torx somewhere here and there, and requires removing & reattaching a cable connector inside the unit. Unplugging & replugging the connector is also a bit sneaky (I don't remember exactly).
