Help from iPhone Users
So I took delivery of my '13 C4S this past weekend! It's awesome and everything I hoped it would be ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I was surprised to find that the AUX bluetooth for music streaming via my iPhone 5 worked just fine. I am running iOS7 7.0.6. PCM with Bose, version 4.4. The first thing I did was delete all previous phones that were in the PCM system (I read that the PCM system will search for all the phones in the list, hurting the bluetooth data bandwidth.)
Then I connected my phone. I leave the bluetooth on in my iPhone and whenever I get in the car, it takes a few seconds, and then "AUX BT" shows up under the SOURCES button menu.
Let me know if there is any other information I can provide -- I want to help! These things can be frustrating, I know![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
ww
ww
This is going to sound dumb- but did you try a different cable? In the last few months I had an apple lightning cable and an hdmi cable go bad, drove me nuts.
Also, how did you get cover art? Is that an update or something?
ww
ww
I don't think getting the album cover, artist name, and track information has anything to do with an update. When I first got the car, I plugged in my phone, and I had full functionality. All of sudden about a month and a half ago, PCM has been saying "no iPod recogized."
Hopefully this is an easy one. Just got my 2014 911 this week and have two questions related to the PCM/iPhone integration. SW Ver 4.63 I believe. I have it discovered in Bluetooth for the phone and all phone functions work as advertised.
1. Is it possible to have music play from the iPhone automatically upon plug in to the USB port in the glove box via lightning cable? I have a pioneer deck in my old 911 that does that and it is awesome.
2. The only way I can change the playing track is through my iPhone. The left right arrows around the PCM volume button only change the song title in the lower PCM field, but the music stays on the current track. If I go through the PCM menu to find a song, when I highlight the desired song and press the right side PCM button, nothing happens and the current song remains playing.
Must be missing something simple. Thanks!
Received 5,404 Likes
Hopefully this is an easy one. Just got my 2014 911 this week and have two questions related to the PCM/iPhone integration. SW Ver 4.63 I believe. I have it discovered in Bluetooth for the phone and all phone functions work as advertised. 1. Is it possible to have music play from the iPhone automatically upon plug in to the USB port in the glove box via lightning cable? I have a pioneer deck in my old 911 that does that and it is awesome. 2. The only way I can change the playing track is through my iPhone. The left right arrows around the PCM volume button only change the song title in the lower PCM field, but the music stays on the current track. If I go through the PCM menu to find a song, when I highlight the desired song and press the right side PCM button, nothing happens and the current song remains playing. Must be missing something simple. Thanks!
Sent from my iPhone using Rennlist
Ditto lex. Using either USB or Bluetooth you need to click 'source' 5 times to select iPod or Bluetooth... As well as a display on the PCM a neat top line appears in the mfd with each click so you can see when you're in the selected source without looking down too long. I got used to the 5 click routine very quickly. In USB mode you can browse and select artists, tracks, albums etc via the pcm... Once selected you can skip tracks etc via the mfd. In bluetooth mode I usually set my track list or album on the phone when I get in the car as you can only skip tracks using Bluetooth. Sound quality is not as good in BT mode and is dependant on handset volume as well as PCM volume whereas in USB mode it is governed entirely by the pcm. Hope this helps
Cheeky, I'm playing through USB and the PCM left/right doesn't control the tracks and I have selected iPod as the source.
Fwiw, I occasionally cannot move from song to song from the center dash mounted forward/reverse track switches. I also occasionally do not see the song info on the PCM. I am using a iPhone 5S via USB.
Only things I can think of trying before dealer visit are...
-Have you tried a hard reset on the phone? (Holding home and power button together until apple logo appears)
-Try car reset by turning on full ignition but without starting the engine... Leave ignition on for 60 secs then start as normal.
-Make sure you have a genuine apple cable. You will see if the phone charges correctly. Replica cables are notorious for being patchy.
-Try Bluetooth mode or try using left/right buttons to scan in radio mode to check if the buttons themselves are functioning correctly.
I can't see why any of the above will necessarily fix the issue but worth 10 mins of your time before you visit the dealer...
Good luck
Ian
Thanks!!!!!
Did the steps you outlined and now it works perfectly. I can select a song via the PCM and the left right buttons work. When I interrupt the music due to a call or unplugging the cable, it automatically starts back up from the last point once the call is over or it is plugged back in.
Still trying to get the music to work in BT mode but not that critical as I always plug the phone in and put it in a cradle for Waze so I get traffic camera alerts. Very important here in Germany as they are all over the place and camoflauged!
Thanks!!!!! Did the steps you outlined and now it works perfectly. I can select a song via the PCM and the left right buttons work. When I interrupt the music due to a call or unplugging the cable, it automatically starts back up from the last point once the call is over or it is plugged back in. Still trying to get the music to work in BT mode but not that critical as I always plug the phone in and put it in a cradle for Waze so I get traffic camera alerts. Very important here in Germany as they are all over the place and camoflauged!
Incidentally I believe you have to tell the car what functions you permit via Bluetooth (at least I did in my last car) so worth checking both phone and music are enabled.
Glad you got it sorted.
