PDK shift lock continuous clicking problem
My 2013 C4S has recently developed a weird problem and I wonder if anyone else has any knowledge about this.
From my understanding, the normal behaviour is this:
PDK, if in neutral, cannot be shifted into D unless you step on the brakes due to the shift lock. So with PDK in N, you can feel a slight click if you lightly step on the brakes to indicate lock release, and if you lift off the brakes you'll feel a click to indicate lock engaged.
This clicking should be at the very top of the brake travel.
Weird behaviour:
In addition to the normal clicking at the top of the brake travel, I have another double-click at about 1/4 of the brake travel down.
So basically if I start wit the PDK in N and brake fully depressed. As I lift off slowly, the PDK lock will do a double click when I'm 1/4 from the top. As I continue to lift off, it will then do the normal click at the very top.
Additional weird behaviour is that if I hold the brake at about 25% depressed (eg at red light) the PDK lock will sometimes actually continuously click on and off rapidly, with a rapid vibration and sound from the PDK stick.
Any ideas?
Weird behaviour:
Any ideas?
