"SAT 3"?
"SAT 3"?
So, I'm traveling, and the PCM was set to "SAT", and I had my 6 Satellite presets, and all was well.
But then I start the car at one point and the PCM is now set to "SAT 3" and my presets are gone. I can't figure out how to get back to the original "SAT" or, in future, should I want to, to get to SAT 3 or, I presume, SAT 2. How many SATs are there? How do you move between them?
TIA...
TIA...
Just touch the "SAT 3" in the upper right corner of the preset screen, and it will cycle through SAT, SAT 2, SAT 3 and the MIXED preset screens.
The MIXED screen is common to all of the tuner inputs and allows you to mix presets from different tuner sources, e.g., FM and SAT.
Yes - just touching the top right should scroll through the options. You will happy to now know that you actually have 18 (6x3) presets too!
FM also has a "Best FM" which are your 6 stations with the best reception. Useful for road trips!!
Enjoy!
Enjoy!
