Spacers on a 50th
Has anyone put spacers on a 50th yet and if so, what size did you install?
Other threads regarding this question for a 4S seem to suggest that 15mm in the rear and 7mm in the front are the preferred sizes.
Any suggestions?
Any suggestions?
Yes, I did try it, and those sizes in fact. The 7mm up front are perfect, but 15mm is too much for the rear, and I ended up with wheel poke. Not sure if the rear Classics have a slightly different offset or what (I thought they might be the same as the Sport Technos, which are also 11.5").
In any event, I'm switching to 7mm all around, which I believe should be perfect. Haven't received the new set of 7s for the rear but will report back when I get them and throw them on.
does the 4S and the 50th have different offsets on the rear wheels vs the base C2 and C2S? ive seen some 4S's around and it looks as though the rear wheels have more of the concave look perhaps due to the wide body of the 4.. and if the 4S does have diff offset, has anybody swapped out the rears on base C2 with wheels that come on 4? I'd be interested in seeing how that looks. perhaps even push the wheels all the way out flush with fender, no need for spacers?
Yes, offsets depend on both body and wheel width. I believe Suzy was the first one to post these, so most of the credit goes to her. The 50th wheels are the same as the Technos for C4/4S (per Suncoast).
Sport Classic wheels (50th)
Front - 9 x 20 ET51 - 245/35 ZR 20
Rear - 11.5 x 20 ET48 - 305/30 ZR 20
Sport Techno wheels
Rear - 11.5 x 20 ET68 - 305/30 ZR 20
Size: Carrera 4/Carrera 4S
Sport Design wheels
Front - 8.5 x 20 ET51 - 245/35 ZR 20
Rear - 11 x 20 ET70 - 295/30 ZR 20
Rear - 11 x 20 ET52 - 305/30 ZR 20
Carrera S wheels
Carrera Classic wheels
Sport Techno wheels
Sport Design wheels
Carrera S wheels
