Shift Assist - how to
Can someone please explain the steps that must be taken for the Shift Assist function to work properly? I read the manual but still cannot get this to work.
The shift assist window is visible on my display but the shift assist digital "gauge" does not change to indicate RPM. I have tried with sport plus on and off with no luck.
I assume I am overlooking something obvious and appreciate any input that you can provide. Thank you.
Funny. I wondered about how this worked too, and suspected I needed to be in the higher RPM ranges. In another easy 400 miles I'll be able to find out. Thanks for your post.
Yes and they have this other funny digital thing that shows you how fast you are going.
(Thanks to all for the responses - once I get a couple more miles on the car I will test it out at 8k)
