I need to polish
Old Mar 28, 2014 | 12:15 AM
jlanka's Avatar
jlanka
Originally Posted by addysdaddy
Depends on the pad manufacturer - unfortunately different colors can mean something different across different lines. Lake Country, Buff & Shine and Meguiars all make quality pads. it is also machine dependent. If your using a DA (dual action polisher-put aside that orbital unless you know what your doing) than let me recommend Lake Country Pads.
For a mild polish, Menzerna 4000 or Sonax 3/6 do really well on German paint - both have a cut level of 3 on a scale of 1-10 (with ten being the most aggressive). Another excellent mild polish readily available from you local auto parts store is Meguiars M205. Do a small test area first to make sure you have the right pad and polish combination. Least aggressive combination first, then step it up if that doesn't work.
Do yourself a favor and buy some quality MF (micro fiber) towels. Microfiber Madness sold exclusively at carpro-usa.com are the hands down best towels on the market and won't scratch your paint. http://www.carpro-us.com/microfiber-madness/ If I had to do to over again, I would only buy their towels. Waverunner for drying and Yellow Fellow for removing polish.
Got the towels. Thanks.
Old Mar 28, 2014 | 12:25 AM
jlanka's Avatar
jlanka
Originally Posted by Money2536
Detailer's Domain Orange (Polish) Pad.
Ordered a 5 pack of the detailers domain pads. Thanks!
Old Mar 28, 2014 | 04:58 AM
wanderfalke's Avatar
wanderfalke
anyone use the cyclo polisher it does seem to be the least aggressive?
Old Mar 28, 2014 | 08:21 AM
Money2536's Avatar
Money2536
I've used the cyclo. It's pretty similar in results to the normal DAs, but it feels different. I would be worried about smacking the metal body against a panel. In my opinion, it's 1950s technology. DAs are already very gentile. I would rate aggressiveness in the following order:
Porter Cable
Cyclo
Griots
Rupes
Flex
Rotary
Old Mar 28, 2014 | 08:59 AM
addysdaddy's Avatar
addysdaddy
Porter Cable
Cyclo
Griots
Rupes
Flex
Rotary
I would agree that a rotary is the most aggressive piece of equipment out there but I would consider all the other DAs in the same boat. It's not about the machine but it's the pad/polish combination that determines aggressiveness. Also there is a technique to using these machines that is very simple but worth learning. Autogeek.net has tons of instructional videos on the proper usage of all these machines - worth watching.
Remember that gloss is derived from how defect free the paint surface is, not from the LSP (last step product). If you wax a dirty car, it's not going to get shiny - it's all about the prep.
Old Mar 28, 2014 | 10:11 AM
Homeles's Avatar
Homeles
Try these guys for microfiber towels. They're from Korea, not that Chinese garbage.
http://theragcompany.com/All-Products_c60.htm
Old Mar 28, 2014 | 02:21 PM
MJBird993's Avatar
MJBird993
I'll ditto the comment earlier about different manufacturers use different colors for their pads.
Also, not only will tap water leave water spots from the minerals, but depending on where you live, acid rain will do the same thing - well, more accurately, it leaves water spots but for different reasons.
Old Mar 28, 2014 | 02:22 PM
MJBird993's Avatar
MJBird993
Porter Cable
Cyclo
Griots
Rupes
Flex
Rotary
Last time I looked, Griots sold relabeled Porter Cable machines.
Old Mar 29, 2014 | 06:24 PM
Money2536's Avatar
Money2536
I'm pretty sure Griot has his own made, but I could be wrong.
