PDK Failure - update
Old Mar 19, 2014 | 03:23 PM
Porschey's Avatar
Porschey
Default PDK Failure - update
Just heard from the dealer on my 2014 Carrera S (with 1100 miles on it) PDK failure. It seems the control unit malfunctioned and that stopped the flow of hydraulics to the transmission, which consequently shut down the transmission. They are replacing the control unit. It's readily available (they will receive it within a day) which means this is not an uncommon issue.
Old Mar 19, 2014 | 03:28 PM
LexVan's Avatar
LexVan
Good news. You should post your update in your orginal thread too:
https://rennlist.com/forums/991/8056...100-miles.html
Old Mar 19, 2014 | 04:28 PM
GSIRM3's Avatar
GSIRM3
Good news. Much better to have an electronic issue than a major mechanical failure.
Old Mar 19, 2014 | 04:50 PM
handful's Avatar
handful
Good to know that you will have your car back sooner rather than later.
Old Mar 19, 2014 | 04:51 PM
stealthboy's Avatar
stealthboy
That's great. You'll be back on the road in no time.
Old Mar 19, 2014 | 10:13 PM
got2go's Avatar
got2go
Had mine replaced today. Gave the car a workout today and no problems.
Old Mar 20, 2014 | 12:42 AM
Porschey's Avatar
Porschey
You had your control unit replaced today for the same issue (PDK)? Did they tell you why it happened? How many miles on your C4S.
Mine is a C2S with X51 powerkit ...I'm wondering if this has something to do with it.
Old Mar 20, 2014 | 01:23 PM
StudGarden's Avatar
StudGarden
I wonder what the retail (out of warranty) cost for that would have been? Would be nice to know.
Old Mar 20, 2014 | 01:25 PM
plenum's Avatar
plenum
Is this a "change-over" valve similar to the following? Maybe you can check your service write-up from dealer tech?
Here's a picture of the part in question (the part number is 7PP906283B, now replaced by 7PP906283C):
There has been a lot of discussion of this particular valve failing on 991s, frequently being related to cabin heating, PSE valves, etc. I had the control changed recently on my 2014 C4S when I had no hot air coming into the cabin.
Failure in this case not allowing flow of hydraulics is much worse than no heat....
2014 C4S - GT Silver/Black, Full Leather, PDK, PS +, Bi-Xenon PDLS, Bose, PASM, Sport Chrono
Old Mar 20, 2014 | 05:39 PM
Porschey's Avatar
Porschey
Thanks for your post and photo. I will check to see exactly aha they replaced when I pick up the car. I am hoping I get it before the weekend. It's going to be a uninspiring weekend with out my baby.
